Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
RedMan542, bdubb, TreePointer, PierreS, GDR
71572 Registered Users
52 registered members (97prizm, BlakeB, 4WD, b1amgm47, Boomer, BigGeo, 5 invisible), 1,342 guests, and 54 spiders.
Topics306,035
Posts5,285,282
Members71,566
Brake Fluid testing - moisture & copper #5389793 03/30/20 10:49 PM
DIY4quality Offline OP
Typically, testing for brake fluid contamination is done at the master cylinder reservoir for obvious reasons. For moisture, it's probably the best place since air bubbles rise and the reservoir is located at the high point of the brake system. So you're getting a sample of the worst moisture condition, a good test.
And copper test strips are also dipped in the reservoir. But I'm thinking a better place would be at the caliper as the low point of the system where particle contamination is more likely to accumulate. Testing at the reservoir, while more convenient, is understating any copper contamination that may be much worse at the components lower in the system.
So I'm very curious to ask if anyone has actually compared a copper test strip at their reservoir with a second test strip at their caliper, perhaps when bleeding the brakes and some expelled fluid was handy?
Re: Brake Fluid testing - moisture & copper [Re: DIY4quality] #5389812 03/30/20 11:25 PM
bdcardinal Offline
I haven't tried it, but I should have a brake flush coming up on my mom's 2014 Fusion which has never had the fluid done.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Brake Fluid testing - moisture & copper [Re: DIY4quality] #5389999 03/31/20 08:14 AM
M
MasterSolenoid Online Content
Online Content
M
I change my Brake Fluid every two years using one quart of fluid each time.
That way I don't need to worry about any testing.
Old Fluid is usually a straw color.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Brake Fluid testing - moisture & copper [Re: DIY4quality] #5390028 03/31/20 09:03 AM
K
KGMtech Offline
K
Test strips are not needed if you replace the fluid every 2-3 years. Just like brake fluid, the test strips are sensitive to exposure to air and become useless, for a DIY person the quantity you have to buy is wasted by the time less than 30% of your original purchase is used up.
I will say, tongue in cheek, that OP has a brake fluid fetish. slobber
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Brake Fluid testing - moisture & copper [Re: DIY4quality] #5390065 03/31/20 09:50 AM
E
ET16 Offline
E
Do the test strips work with all types of coolant? I thought I heard that were only good for conventional, green coolant.
Re: Brake Fluid testing - moisture & copper [Re: KGMtech] #5390072 03/31/20 10:03 AM
Originally Posted by KGMtech
... I will say, tongue in cheek, that OP has a brake fluid fetish. slobber
Yes indeed, that's why I'm here and more to come! wink
Re: Brake Fluid testing - moisture & copper [Re: ET16] #5390074 03/31/20 10:06 AM
That's true for the coolant strips. My question is in regard to the brake fluid strips.
Note that some strips have the brake fluid test pad on one side of the strip, and the coolant test pads on the other side of the strip.
