P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
57 registered members (aba4430, Best F100, ArrestMeRedZ, aquariuscsm, AurionX2, 4WD, 3 invisible), 1,602 guests, and 86 spiders.
Topics306,051
Posts5,286,421
Members71,593
Air conditioner in a toyota avalon #5389636 03/30/20 06:11 PM
ChrisSnowden Offline OP
I have a 2009 toyota avalon. The a/c system has stopped working. The fan usually doesnt run but sometimes it comes on. If I take it off of recirculate cold air comes out the vents when I'm at speed. Today the fan came on but blew hot air. I tried to charge the system today since the fan was running at full speed but the gauge on the refrigerant pegged in the red zone. I dont believe it is overcharged, it acted like the refrigerant couldnt get through the valve and backed up into the hose. the compressor was turning on for about a second and then turning back off repeatedly.
Any ideas what may be wrong?
Re: Air conditioner in a toyota avalon [Re: ChrisSnowden] #5389640 03/30/20 06:18 PM
K
Kansas_Ron Offline
K
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: Air conditioner in a toyota avalon [Re: ChrisSnowden] #5389665 03/30/20 07:15 PM
dnastrau Offline
If it turns out to not be something simple like a bad relay...
You will probably not get accurate results trying to charge a system with one of those r134a cans with the gauge on it, as that gauge only measures low side pressure. The high side pressure is critical in making sure that a system is not overcharged.
If you don't have access to an r134a manifold gauge set, you really should take it to a reputable shop who can check the low and high side pressures properly. It will save you a lot of headaches in the long run. Trying to run a system with pressures too high, too low, too much or too little refrigerant oil, moisture or contamination in the system, etc. can cause expensive damage.
I hope it turns out to be a simple, inexpensive problem. Stay safe as well - released refrigerant can freeze body parts.
Andrew S.
Re: Air conditioner in a toyota avalon [Re: ChrisSnowden] #5389693 03/30/20 07:55 PM
A
atikovi Offline
A
Isn't the red zone indicative of overcharge? The gauge reads the pressure of the system not just the hose. Why do you think the hose is plugged?
Re: Air conditioner in a toyota avalon [Re: ChrisSnowden] #5389697 03/30/20 08:10 PM
Chris142 Offline
I assume you have a can with a low side gauge. If so those pressures do not mean anything. You need both a high and low side gauge to diagnose it and even that can be spotty with R134a. It needs to be properly charged by weight before we can do any diagnosing.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Air conditioner in a toyota avalon [Re: ChrisSnowden] #5389747 03/30/20 09:23 PM
M
mk378 Offline
M
Pressures especially don't mean anything when the compressor is not running. It sounds like there is an electrical problem. The inside fan should always run with the switch on, the air selector works and the temperature dial changes from heated to ambient. Once all that works then you can look at diagnosing the A/C.
Re: Air conditioner in a toyota avalon [Re: ChrisSnowden] #5389908 03/31/20 05:22 AM
Char Baby Offline
You mentioned the "Fan" usually doesn't run but sometimes it com es on"
Do you mean the radiator fan or the inside HVAC fan?
When filling the AC unit, the "COMPRESSOR" itself needs to be running(AC clutch engaged) in order for the system to accept refrigerant. I sound like some refrigerant went into they system. But in order to get a more accurate reading on the gauge, the compressor itself need to be running.
The radiator fan will turn on too when the AC clutch is engaged but, don't mistake a running radiator fan as the AC compressor being ON(engaged).
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Air conditioner in a toyota avalon [Re: ChrisSnowden] #5389984 03/31/20 07:59 AM
G
Gebo Online Content
Online Content
G
I do have some advice based on my experience. Please ask around and find a trustworthy and competent AC shop. From my experience, I have never been successful trying to self diagnosis any of my AC problems.
I bought the gauges, refrigerant, scales, etc. Wasted days of my life after work.
On my my last fiasco, after I had gone to the wrong repair shop at the tune of $1100, I called my local Lexus "dealer". They told me where they go. I called their guy and he said he seldom replaces individual components.
In my situation he would flush and replace "everything" with OEM parts and that would cost me $1300. If I had only known...
Something about how the lines can be contaminated and the only way to be sure is to replace it all. I now agree with him.
Why is it we seem to distrust AC repair men more than general mechanics?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Air conditioner in a toyota avalon [Re: Gebo] #5389992 03/31/20 08:05 AM
A
atikovi Offline
A
Why does a home window a/c unit at Home Depot that cools an entire room cost $99 while just the compressor for a car can be 3 times as much, is what I want to know.
Re: Air conditioner in a toyota avalon [Re: ChrisSnowden] #5390070 03/31/20 10:01 AM
M
mk378 Offline
M
Car systems have 3 to 6 times the BTU capacity of the little window unit.
