Its not very clear what you are trying to do and did already but if you are trying to get pictures off your android phone to your PC, I recommend, you just put the USB cable in and copy the pictures. Once you stick the cable in the phone and PC, you will pull down the top menu of the phone and select File Transfer mode, your phone will become visible in explorer. If that does not happen, you will need to install generic MTP drivers for Windows.
If that's too complicated, install Dropbox on the phone as well as Windows. Log in to both places. Go to Dropbox android app settings and select upload photos. It will keep the phone and PC synced.
Pls comment if you need pictures/screenshots to help you get a clearer idea.
