Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
25 registered members (A_Privateer, Char Baby, alchargo, chemman, blufeb95, ArrestMeRedZ, 1 invisible), 1,310 guests, and 66 spiders.
Topics306,079
Posts5,286,958
Members71,596
Page 1 of 4 1 2 3 4
Heaviest 5w-30 Synthetic? #5389380 03/30/20 11:53 AM
Propflux01 Offline OP
Can anyone tell me what synthetic is “thickest”? I.E. highest range on the 30 side?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389383 03/30/20 11:57 AM
B
BMWTurboDzl Offline
B
Generally 30w oils which are ACEA A3/B4 or C3 are on the heavy side. These are your Euro spec oils (BMW LL01/LL04, Benz 229.50/51, Porsche C30, etc)
Redline maybe Amsoil has some oils on the thicker side for their weights.
435i
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389384 03/30/20 11:58 AM
J
jayjr1105 Offline
J
I think there is a way to sort oils on pqia site by their viscosity, hang tight...
Maybe not. PQIA site has changed so much, I think that feature went away.
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389387 03/30/20 12:03 PM
T
Triple_Se7en Offline
T
Judging by your Korean models in your Signature and probably needing SN Plus ....
Quaker State Ultimate
Rotella Gas & Truck
Google both for data sheets.
However, Thickest is not Bestest. If it were, both of my Korean vehicles would be using ^^those-2^^
In mid-priced ($23-$35) 5w30s I like - in no particular order....
Pennzoil Ultra Platinum
Pennzoil Platinum
Mobil-1 AP
Mobil-1 EP
Valvoline Modern Engine
Valvoline Advanced
Kendall GT-1
Castrol Edge EP
Mag-1 Synthetic (I found at NAPA)
It's my Fine-As-Wine 9...... without the need to take a loan-out, for five quarts of TGDI / GDI oil.
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389402 03/30/20 12:22 PM
P
Powerglide Offline
P
5w-40
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389403 03/30/20 12:24 PM
O
Olas Offline
O
Redline has crazy HTHS, their 5w30 is heavier than most people’s 40 (3.7 advertised vs. <3.5 ACEA spec)
Re: Heaviest 5w-30 Synthetic? [Re: Powerglide] #5389427 03/30/20 12:56 PM
Chris142 Offline
Originally Posted by Powerglide
5w-40
10w-40!
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389480 03/30/20 02:12 PM
B
blufeb95 Online Content
Online Content
B
Mobil1 High Mileage, they're not 5w30, but the Euro spec'd 0w30 oils tend to run on the thick side closer to a 40.
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389482 03/30/20 02:14 PM
A
aquariuscsm Offline
A
Isn’t Edge and QSUD on the thicker W30 side?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Heaviest 5w-30 Synthetic? [Re: aquariuscsm] #5389496 03/30/20 02:32 PM
B
Online Content
B
around 11CSt, more Middle of the road, unless you're talking about the A3/B4 or C3 EDGE those are closer to 12.
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389512 03/30/20 02:49 PM
slug_bug Offline
These results are from 2013. Don't know if you can assume similar performance today.
http://www.pqiamerica.com/March2013PCMO/Marchsyntheticsallfinal.html
2017 RX350 (42k)
2016 Miata 2.0l (24k)
2013 Fusion 2.5l(102k)
2013 Focus(76K)
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389538 03/30/20 03:23 PM
Thanks guys for the info!
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389548 03/30/20 03:43 PM
M
Mainia Offline
M
Mobil 1 5w-30 ESP 11.8 @100C HTHS 3.5
I am running it in my Hyundai turbo.
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Heaviest 5w-30 Synthetic? [Re: Propflux01] #5389551 03/30/20 03:53 PM
RDY4WAR Offline
Driven LS30 5w-30 is 12.1 cSt.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Heaviest 5w-30 Synthetic? [Re: slug_bug] #5389589 03/30/20 04:44 PM
J
jayjr1105 Offline
J
Yes thank you. I had mentioned that earlier but I couldn't find the link anymore on pqia.org
Page 1 of 4 1 2 3 4
