"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
Scam: Ghana $+2 - US $-2
by pandus13 - 06/02/20 01:09 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
41 registered members (ctechbob, bbhero, blufeb95, carlprop, CPA1989, BlakeB, 5 invisible), 1,290 guests, and 74 spiders.
Topics306,078
Posts5,286,944
Members71,596
Upgrade from HDD to SSD #5389370 03/30/20 11:39 AM
diyjake Offline OP
I bought a Samsung EVO 860 500gb SSD to upgrade the hard drive on my 1.5 year old Lenovo laptop. This will be my first time doing something like this so any info you guys can share would be much appreciated.
I was originally going to clone my current hard drive to the new SSD but a few people told me to do a fresh windows 10 install. Will the fresh install really make the much difference? My laptop was barely used and it was used lightly for some photos, emailing and word documents, no games or major downloads.
whether I clone or do a fresh install what would be the correct procedure?
Re: Upgrade from HDD to SSD [Re: diyjake] #5389373 03/30/20 11:43 AM
L
Leo99 Offline
L
I went fresh install when I upgraded. You put Win10 on a USB drive and you're ready to go.
Without data you're just another person with an opinion. W. E. Deming
2004 Corolla 125,000 miles
2004 Rav4 399,852 miles (RIP)
2015 Camry 101,000 miles
2020 Rav4 6,000 miles
Re: Upgrade from HDD to SSD [Re: diyjake] #5389400 03/30/20 12:22 PM
IMSA_Racing_Fan Offline
I went with a fresh install on an older laptop and WOW blazing speed! When the SSD's came out I was skeptical but I'm a believer now (but I still backup to a regular HDD everything I want to keep). You will be pleased with the result.
2012 Cadillac CTS 3.0
1997 Ford Aspire
1991 Jaguar XJ6
1986 Kawasaki ZG1000 Concours
Re: Upgrade from HDD to SSD [Re: diyjake] #5389404 03/30/20 12:24 PM
B
Bottom_Feeder Offline
B
Really, it depends on how savvy you are and how much time you want to spend on it. Personally, I would never clone a spinning drive to an SSD simply because swapping parts, installing Windows, updating drivers and restoring data is easy, even enjoyable for me.
If you do a fresh install, Windows 10 is pretty good about installing workable recent drivers for most hardware, so more than likely it'll work fine after Windows finishes installing and it does the first round of updates. No real need to track down the latest and greatest from every hardware manufacturer.
Re: Upgrade from HDD to SSD [Re: diyjake] #5389408 03/30/20 12:27 PM
N
NateDN10 Offline
N
Just a month ago or so I used Macrium Reflect to clone a Windows 10 installation from a 250 GB 5400RPM 2.5" drive to a 240 GB SSD. Due to the small size decrease I had to resize the main data partition during the clone. It went smooth as butter though, and wow what a huge improvement in speed!
I followed this guide: https://knowledgebase.macrium.com/display/KNOW/Cloning+a+disk
2016 Mazda3 - 20,000 mi.
2011 Toyota Sienna - 100,000 mi.
Re: Upgrade from HDD to SSD [Re: diyjake] #5389416 03/30/20 12:37 PM
L
LvR Online Content
Online Content
L
Whatever route you choose to follow, make sure you have a Microsoft account linked to this particular machine BEFORE you start - especially if you dont have a key and only a typical modern digital license. Once done, re-activation is totally automatic
Re: Upgrade from HDD to SSD [Re: diyjake] #5389420 03/30/20 12:46 PM
diyjake Offline OP
I understand the need to do a fresh install on an older laptop but on a laptop like when where it was hardly used, no games or downloads does it really make much difference? I guess it would delete unnecessary junk that was installed by Lenovo?
Re: Upgrade from HDD to SSD [Re: LvR] #5389421 03/30/20 12:48 PM
diyjake Offline OP
How can I confirm this?
Re: Upgrade from HDD to SSD [Re: diyjake] #5389431 03/30/20 01:00 PM
P
PandaBear Offline
P
Personally I'd just clone it. Yes if you do a fresh install the performance will be better, but if you clone correctly you should still be fast enough and durable enough. The amount of work to reinstall is probably not worth the gain.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Upgrade from HDD to SSD [Re: diyjake] #5389434 03/30/20 01:02 PM
P
PandaBear Offline
P
Don't worry about that, you have a laptop so the license key should be a sticker on it already. If you have a home build machine and you don't have the original key then it may be a problem, but not in your situation.
Re: Upgrade from HDD to SSD [Re: diyjake] #5389455 03/30/20 01:29 PM
diyjake Offline OP
What is a good cloning program? I'll have to check maybe the Samsung SSD hard drive came with one.
Re: Upgrade from HDD to SSD [Re: diyjake] #5389463 03/30/20 01:41 PM
R
Rand Offline
R
I would clone it.
fresh install will keep you going for hours.. need to find all the lenovo drivers.
you will lose the lenovo restore partition etc.
Re: Upgrade from HDD to SSD [Re: diyjake] #5389469 03/30/20 01:53 PM
Quattro Pete Offline
Samsung SSD comes with data migration software, or you can download it from their website. That's what I used when I moved from HDD to SSD on my laptop. You will need a USB to SATA cable to accomplish this.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Upgrade from HDD to SSD [Re: diyjake] #5389495 03/30/20 02:31 PM
diyjake Offline OP
Is there a program that I can use to watch the health of a hard drive?
Re: Upgrade from HDD to SSD [Re: diyjake] #5389506 03/30/20 02:41 PM
Yes, Samsung Magician, also available for download from their website.
