I just found that I have leaking wheel cylinders on both of the rear drum brakes of my 1993 Oldsmobile Ciera 3.3L - no ABS. One side is so bad that the brake pedal has gone soft so I'm taking the car out of service until this is fixed. I'm working on the parts list order.
The brake shoes have lot's of life left but it's all pretty much a nasty mess with fluid on about everything.
1. I wonder if I can clean the brake shoes or does the brake fluid soak and contaminate the friction material so much that it will not be good to re-use them ?
2. Should I get new wheel cylinders, or just those cylinder rebuild kits that have the new rubber caps and springs? (A few dollars cost isn't the issue but thought installing the kit might mean not having to risk rounding off that brake line nut that goes into the back of the wheel cylinder body)
3. If anyone happens to know what size "E" socket will fit those bolts that GM used to hold the wheel cylinders that would be useful. I only have a E6 which is too small so I'll have to buy a bigger one. Perhaps an E8 or E10 ?
