Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Honda GC vs GS engines?
by Avery4 - 05/28/20 01:10 PM
Advanced auto parts
by Fitter30 - 05/28/20 12:52 PM
Is there a best time to switch to synthetic oil?
by Jgelack - 05/28/20 12:37 PM
Alignment good then bad
by Barkleymut - 05/28/20 11:56 AM
What's in the Box?
by BeerCan - 05/28/20 11:31 AM
High Gloss product for Silver car?
by tc1446 - 05/28/20 11:15 AM
oldcodger, cwllams1, Danwrig, DanielR, lagreca
71557 Registered Users
109 registered members (2004tdigls, 55hambone, 928, AandPDan, 53' Stude, 12 invisible), 2,230 guests, and 36 spiders.
Topics305,990
Posts5,284,276
Members71,557
cooling system vacuum refill kit #5389161 03/30/20 07:35 AM
Donald Offline OP
I see HF has one that is less than the name brands. Any try this one?
https://www.harborfreight.com/autom...ng-system-test-and-refill-kit-64985.html
Unsure if it needs to be held in place until there is enough vacuum or does it have a way of expanding a rubber piece that holds it in place.
Comments?
2015 Ford F-250 w/Powerstroke
Re: cooling system vacuum refill kit [Re: Donald] #5389173 03/30/20 07:47 AM
L
LotI Online Sleepy
Online Sleepy
L
The pictures clearly show adapters to fit different necks. Like most HF tools it’s a copy of an existing kit.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
19 Buick Regal TourX
Re: cooling system vacuum refill kit [Re: Donald] #5389220 03/30/20 08:32 AM
J
JC1 Offline
J
Here is a review from the HF website.
Originally Posted by HF User
First use. Seems to work just fine!
I appreciate that HF made this tool! I needed it to test and fill my N63 (550i). It seems to work as expected. I had some difficulty getting a proper seal on the reservoir, but it doesn't seem like that's a tool deficiency. The tool seems robust, like it may withstand moderate impact. The device is heavy, and seems like it's made from dense polymer. The 6 rubber grommets included are various sizes, and designed to fit into the coolant reservoir. The rubber adapters are soft and malleable, which I expect means that they are made from sufficient quality rubber. The tool core, which is tightened to seal the device to the vehicle and act as an orifice to deliver fluid, appears to be made of anodized aluminum. Anodized aluminum seems better than steel in this application because it may have less reactivity with ethylene glycol (and variants). I experienced some trouble when trying to hold a vacuum with the device. Upon reflection, it seems the weight of the attached compressor hose would pull the device slightly ajar, breaking the seal with the reservoir. I realized after I disconnected the tool that may be the purpose of the small hook affixed to the top of the device. Regardless of my inability to use the tool properly, I was able to pull a vacuum on the cooling system, and dunked the intake hose into the coolant bottle. The intake filter fits into a standard coolant jug, but it seemed like the intake filter diameter was too large to fit into a standard gallon water jug. Closing the compressor valve and releasing the coolant intake valve caused the cooling system to drain a jug of coolant. When the first jug was empty, I moved the intake into the next jug, recharged the vacuum, and drained another bottle of coolant. Let the car sit overnight and no visible leaks remained. While I may have lacked the acuity to properly use the tool, it seems like it performed as expected. One negative observation arose from cleanup. When the threaded compressor adapter (nipple) is fitted to the tool and the tool placed in the storage case, the nipple protrudes upwards and prevents the case from closing. So, the nipple needs to be removed for storage and reinstalled when the tool needs to be used. A relatively minor gripe, considering I do not expect to use the tool daily.
Steve
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: cooling system vacuum refill kit [Re: Donald] #5389230 03/30/20 08:40 AM
A
atikovi Offline
A
Spend the extra $40 on the real deal. https://www.tooltopia.com/uview-550..._Eg-0xqR98ozmzf9mYsxCHZaviEaAv9CEALw_wcB You'll be glad you did.
Re: cooling system vacuum refill kit [Re: Donald] #5389260 03/30/20 09:02 AM
F
Fattylocks Offline
F
Yes .
Most likely will fall apart in your hands the first time you attempt to use it.
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 Mustang GT Convertible sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
Re: cooling system vacuum refill kit [Re: atikovi] #5389290 03/30/20 09:31 AM
Donald Offline OP
Airlift sells 3 kits. What is the difference. Which best for my PSD?
Re: cooling system vacuum refill kit [Re: Donald] #5389297 03/30/20 09:39 AM
A
atikovi Offline
A
Looks like they have an economy version to save you $30 or $40, but how much is a coolant service at a shop going to cost you one time vs. the more expensive tool you can use for years.
Re: cooling system vacuum refill kit [Re: Donald] #5389301 03/30/20 09:44 AM
Donald Offline OP
The Ford dealer is $400 for both cooling systems. And they may not use distilled water.
Re: cooling system vacuum refill kit [Re: Donald] #5389539 03/30/20 03:24 PM
Donald Offline OP
If you had old coolant in the radiator or block would it pull that out as its trying to pull a vacuum? Or just remove air?
Re: cooling system vacuum refill kit [Re: Donald] #5389544 03/30/20 03:37 PM
B
boom10ful Offline
B
I bought and used the OTC branded coolant vacuum tool and it works great! Didn't have to top off the overflow after a few cycles. It would have been a pain to drain and fill the inverter cooling system without it!
2003 Hyundai Santa Fe (RIP) 148K
2016 Hyundai Sonata Hybrid 86K
Re: cooling system vacuum refill kit [Re: Donald] #5389546 03/30/20 03:40 PM
T
Trav Offline
T
Re: cooling system vacuum refill kit [Re: Trav] #5389599 03/30/20 05:05 PM
skyactiv Online Content
Online Content
Bought the same one from your recommendation 2-3 years ago and used it to change the coolant on a VW GTI I once had and my wife's Audi.
It worked good.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: cooling system vacuum refill kit [Re: Donald] #5389617 03/30/20 05:35 PM
The Critic Offline
The U-View economy kit works well. I used it for years before it broke:
UView 550500 Airlift II Economy Cooling System Refiller https://www.amazon.com/dp/B000IHK1VI/ref=cm_sw_r_cp_api_i_OnNGEbADAB64M
If you want to invest more, I highly recommend upgrading to the style that uses application specific caps. The cap style ones seem to suck down the system a lot faster.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: cooling system vacuum refill kit [Re: The Critic] #5390849 04/01/20 11:04 AM
Donald Offline OP
Where did you get the one in the picture. I cannot make out the brand.
Re: cooling system vacuum refill kit [Re: Donald] #5407876 04/19/20 02:36 PM
K
KirklanC Offline
K
I bought this HF tool and it works great.
My LSA supercharger intercooler system was a pain to bleed. This tool made it fast and simple to fill and bleed all at once.
Then the truck cooling system was done in 1 simple operation. Bleed and filled and done.
2012 Silverado.
It did not break leak or disappoint. It does not feel cheap.
It works well
