Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
RedMan542, bdubb, TreePointer, PierreS, GDR
71572 Registered Users
57 registered members (Best F100, 2009Edge, alarmguy, 4WD, 97prizm, b1amgm47, 7 invisible), 1,388 guests, and 47 spiders.
Topics306,035
Posts5,285,285
Members71,572
What tool do I need? #5388954 03/29/20 08:51 PM
2015_PSD Offline OP
I want to create a 7/8" diameter flat bottomed recess in a thick piece of aluminum. The intent is to use it on top of a floating nut as gun slide support.
Thanks in advance for your help!
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: What tool do I need? [Re: 2015_PSD] #5388959 03/29/20 08:56 PM
spasm3 Online Happy
Online Happy
Forstner bit with a lot of cutting oil should work.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: What tool do I need? [Re: 2015_PSD] #5388962 03/29/20 09:00 PM
P10crew Online Content
Online Content
That would be a center cutting end mill in a milking machine.
Re: What tool do I need? [Re: 2015_PSD] #5388997 03/29/20 10:06 PM
samven Offline
If you have a friend with a mill or lathe get them to help otherwise make sure you have a spare piece of aluminium. If you have a piece of 6061 T4 you should be able to slowly cut a hole with a good forstner bit and a lot of oil or water. You will need a drill press set to its slowest speed. You could buy a flat bottomed end mill but for what a 3/4" end mill will cost you could get it cut at a machine shop. If you have that cheap soft stuff from a home store, well lets just say you probably wont get the results you want. Unhardened or unhardenable aluminium is sticky and will stick to the cutting edge of your bit and you will get tearing and lots of heat. Have a small stainless toothbrush like you get at Harbor Freight and pull the bit or mill out every 10 sec and brush the cutting edge off.
Re: What tool do I need? [Re: 2015_PSD] #5389284 03/30/20 09:28 AM
F
Farnsworth Offline
F
How flat and how deep? It sounds like you could use a 7/8 wood bit. the cheap two flute kind. There will be a smaller center hole for the point. Drill a pilot hole and if your needs aren't too deep for the recess I think it would work, maybe have to dull two of the drills.
Re: What tool do I need? [Re: 2015_PSD] #5389335 03/30/20 10:35 AM
E
Elkins45 Offline
E
You could probably get away with an end mill bit in a variable speed router. The guys cutting 80% AR lowers are using those.
Re: What tool do I need? [Re: 2015_PSD] #5389604 03/30/20 05:16 PM
F
Farnsworth Offline
F
Another way to do it is drill a hole all the way through, then fix a plug in to the depth you need. Or take a piece of aluminum the depth of the hole, drill a 7/8 hole in it and fix that to the main plate.
Re: What tool do I need? [Re: 2015_PSD] #5389660 03/30/20 07:04 PM
2015_PSD Offline OP
Thanks guys. It is T6061 so I will try a forstner bit with oil. I only need to cut about 1/8" deep to give enough depth to hold the nut in place.
Re: What tool do I need? [Re: 2015_PSD] #5389701 03/30/20 08:14 PM
spasm3 Online Happy
Online Happy
Even better that its a shallow hole. the deeper , the more the shavings stick to the sides of the forstner bit and mess up the sides of the hole.
Re: What tool do I need? [Re: 2015_PSD] #5389953 03/31/20 07:02 AM
K
ka9mnx Online Content
Online Content
K
A hole punch used for metal cabinets.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
