Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
33 registered members (AndyB, ctechbob, daves87rs, DeafBrad, bbhero, 830Lee, 1 invisible), 1,450 guests, and 47 spiders.
Topics306,109
Posts5,286,657
Members71,586
Broken sway bar bolt #5388765 03/29/20 04:00 PM
H
HoosierJeeper Offline OP
H
Ideas on what to do with this one? Head snapped off, the shank is stuck in the LCA. Tried vice grips without luck
Thanks!
19 Jeep Renegade Trailhawk 1.3T
15 Jeep Cherokee Limited V6
07 Land Rover LR3 SE V8
05 Jeep Liberty Limited V6
96 Jeep Cherokee Country 4.0
Re: Broken sway bar bolt [Re: HoosierJeeper] #5388769 03/29/20 04:05 PM
L
LazyDog Offline
L
You need to put some heat and may be it come loose.
Re: Broken sway bar bolt [Re: HoosierJeeper] #5388770 03/29/20 04:07 PM
spasm3 Online Happy
Online Happy
Weld a nut on it.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Broken sway bar bolt [Re: HoosierJeeper] #5388799 03/29/20 04:59 PM
T
TurboLuver Offline
T
Blue flame wrench.
2015 Lexus GS350 F Sport RWD
2008 Civic SI
1999 GMC Suburban K2500
1997 Jeep Cherokee Country
Re: Broken sway bar bolt [Re: TurboLuver] #5388854 03/29/20 06:35 PM
M
mattd Offline
M
Weld a nut to it; or heat it and use a bolt extractor
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Broken sway bar bolt [Re: HoosierJeeper] #5388942 03/29/20 08:38 PM
A
andyd Offline
A
No torch or welder? Pound on it a little,then try to tighten it with the Vise Grips. If you can move it in either direction the slightest bit, you'll be able to back it out by working back and forth in increasing arcs and lots of oil. When that doesn't work, Plan B is to cut or grind the bolt down to about 1/8 above arm and start drilling. Start with a 1/8, then a 3/16, 1/4 or better a 9/32. Then with a blunt screw driver push the remnants in the hole you've created. Clean debris out with needle nose pliers. Plan C is an EZ out grin2
Thick oil is better grin2
Re: Broken sway bar bolt [Re: HoosierJeeper] #5388977 03/29/20 09:25 PM
H
H
Thanks for the tips everyone! Is a propane torch good enough?
Re: Broken sway bar bolt [Re: HoosierJeeper] #5389051 03/30/20 01:58 AM
A
anndel Offline
A
Like others mentioned, heat or welding a nut to it.
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - Amsoil SS 10W-30, Amsoil FIlter
2005 Toyota Avalon XL, 3.5L V6, Amsoil SS 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Broken sway bar bolt [Re: HoosierJeeper] #5389144 03/30/20 07:24 AM
H
H
Got it! The propane torch got it red hot. Then used more PB blaster, and vice grips with the jack handle on them to turn it out. And some help from the ol BFH.
Thanks for the help everyone!
Re: Broken sway bar bolt [Re: HoosierJeeper] #5389156 03/30/20 07:32 AM
gathermewool Offline
Woohoo!
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Broken sway bar bolt [Re: HoosierJeeper] #5389214 03/30/20 08:28 AM
sw99 Offline
Nice job getting it removed!
Re: Broken sway bar bolt [Re: HoosierJeeper] #5389320 03/30/20 10:09 AM
H
H
Thanks!!! Glad that everyone told me the same thing so I didn't have an excuse to not try the torch lol!
