Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
66 registered members (3turbodiesels, ammolab, 87sammy, Ag76, 2003f7, 4 invisible), 1,789 guests, and 35 spiders.
Topics306,109
Posts5,286,633
Members71,586
can I use it? #5388760 03/29/20 03:54 PM
A
avi1777 Offline OP
A
hi folks,
if my manual requires api and ilsac specs can I or am i better off using thos specs in addition
API SN ACEA C2/C3
FIAT9.55535-S1 \ S3
GM DEXOS2
MB229.51
VW 505.01
BMW LL04
or should I strickly stick to an sn/gf spec only?
tnx
Re: can I use it? [Re: avi1777] #5388766 03/29/20 04:00 PM
A
avi1777 Offline OP
A
or using an a3/be for that matter,
fuel economy is secondary to me,looking for the highest spec I can use.
now using the motul eco lite w30 which is a d1g2 and sn,hths3.3 and happy with it but the x cess is looking even better.more specs,higher hths,
tempting...
Re: can I use it? [Re: avi1777] #5388789 03/29/20 04:45 PM
B
Bjornviken Offline
B
yes, you can use it...
Re: can I use it? [Re: avi1777] #5388867 03/29/20 07:02 PM
G
Gokhan Online Content
Online Content
G
GM dexos2 is a tough standard. However, for GM dexos2 or ACEA C3, HTHS ≥ 3.5 cP, and your fuel-economy will be a few percent lower. Since it also satisfies the better-fuel-economy ACEA C2 spec, I would say about 2% lower fuel economy than for a typical ILSAC oil. Your oil pressure will also be higher. Nevertheless, it won't do any harm, and it may be beneficial in reducing wear in high-speed driving.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: can I use it? [Re: avi1777] #5389044 03/30/20 01:38 AM
O
Olas Offline
O
A3/B4 is good, Porsche A40 is measurably better wink
Re: can I use it? [Re: avi1777] #5389045 03/30/20 01:41 AM
A
avi1777 Offline OP
A
as far as i know the sn spec is low ash right?
are the specs above low mid or high ash?
tnx guys
Re: can I use it? [Re: avi1777] #5389046 03/30/20 01:52 AM
O
Olas Offline
O
505.01 is high saps
Re: can I use it? [Re: avi1777] #5389052 03/30/20 02:04 AM
A
avi1777 Offline OP
A
so just to be clear i need a low saps oil?its a gasoline 2.5 n/a engine.
Re: can I use it? [Re: avi1777] #5389059 03/30/20 02:13 AM
A
avi1777 Offline OP
A
as far as i remember i can use use low to mid saps and high saps is bad for the converters,
please correct me if im wrong.
Re: can I use it? [Re: avi1777] #5389060 03/30/20 02:14 AM
G
Online Content
G
Low-SAPS oils (SA ≤ 0.5%) are virtually nonexistent. All specs you posted here are mid-SAPS -- SA ≤ 0.8%. ILSAC oils typically have SA = 0.8 - 1.0%; so, they tend to be a little higher in SA than the European mid-SAPS oils.
Any oil is fine for your engine, but I would avoid full-SAPS oils (ACEA A3/B4, typically SA ~ 1.3%) for peace of mind (emissions durability).
Re: can I use it? [Re: Gokhan] #5389068 03/30/20 03:43 AM
A
avi1777 Offline OP
A
tnk u gokhan,
this is a low saps oil they do exist
https://www.motul.com/mx/en/products/8100-eco-clean-5w30--2
Re: can I use it? [Re: Olas] #5389073 03/30/20 03:55 AM
A
avi1777 Offline OP
A
Originally Posted by Olas
505.01 is high saps
here it says it is mid saps
https://d23zpyj32c5wn3.cloudfront.net/images/product_descriptions/technical_data_sheets/83155/8100_X-clean_EFE_5W-30_%28GB%29.pdf?1545234968
Re: can I use it? [Re: avi1777] #5389074 03/30/20 04:04 AM
A
avi1777 Offline OP
A
Re: can I use it? [Re: avi1777] #5389088 03/30/20 05:20 AM
G
Online Content
G
tnk u gokhan,
Thanks. ACEA is getting rid of the C1 category, which is low-SAPS, lower-HTHS (~ 3.0 cP), later this year. It is being recommended by only one OEM. C4 will remain, which is low-SAPS, high-HTHS (3.5 cP and above).
Re: can I use it? [Re: avi1777] #5389089 03/30/20 05:21 AM
G
Online Content
G
505.01 is high saps
Yes, MB 229.51 and VW 505.01 are mid-SAPS.
There is no high-SAPS. There are only low-SAPS, mid-SAPS, and full-SAPS.
