Infineum article and resource repository
by Gokhan - 05/30/20 05:02 AM
TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
34 registered members (4WD, b1amgm47, BigGeo, Amkeer, BeerCan, 4 invisible), 1,328 guests, and 49 spiders.
Topics306,035
Posts5,285,280
Members71,566
Service Champ OF2222 75% OLM, unknown miles #5388756 03/29/20 03:50 PM
B
bullwinkle Offline OP
B
This little "gem" of an Ecore was on the Express 6.0 in my sig when I bought it, it had approximately 5000 miles or so, 25% OLM remaining, but the Jiffy Lube used NON-Dexos rated bulk 5W30 QSAD/green bottle, along with this filter. It caught some crud, but ADBV action was failing (noisy startup after sitting more than a couple days), and end caps looking a little erratic near the seam. Held together reasonably well, wondering if it maybe was a combo bypass design? Oil pressure improved slightly with the RGT 5W30 & new style PH10060, which I'll run for around 3500 miles to flush it out & come back with RGT & Baldwin then. [Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Service Champ OF2222 75% OLM, unknown miles [Re: bullwinkle] #5388768 03/29/20 04:04 PM
53' Stude Offline
Mehta, looks ok. Glad you put good filter back on. Thanks for c&p
2009 Toyota Camry LE
Re: Service Champ OF2222 75% OLM, unknown miles [Re: bullwinkle] #5388857 03/29/20 06:41 PM
Z
ZeeOSix Offline
Z
Originally Posted by bullwinkle
...wondering if it maybe was a combo bypass design?
The two set of holes in the base plate it looks like those used with a ADBV/Bypass combo valve. No photo of the rubber valve, so hard to say.
Re: Service Champ OF2222 75% OLM, unknown miles [Re: bullwinkle] #5388886 03/29/20 07:23 PM
U
Ursatdx Offline
U
Doesn't the filter sit vertically (bottom down)?
Can't see how you can conclude a faulty ADBV.
How do you know a non Dexos oil was used?
Are you sure the oil was changed when the OLM was reset?
Can anyone decipher the date code on the filter?
Be well.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Service Champ OF2222 75% OLM, unknown miles [Re: Ursatdx] #5388892 03/29/20 07:43 PM
53' Stude Offline
Be well.
12/14/18 or December 2018: date code
Re: Service Champ OF2222 75% OLM, unknown miles [Re: bullwinkle] #5388909 03/29/20 07:58 PM
K
kstanf150 Offline
K
Looks pretty nasty to me guys, how many miles on your engine ?
Re: Service Champ OF2222 75% OLM, unknown miles [Re: bullwinkle] #5388926 03/29/20 08:24 PM
Z
ZeeOSix Offline
Z
Need a photo of the ADBV. That engine may have a in-block bypass valve ... not sure because GM has gone back and forth on that with newer engines.
Re: Service Champ OF2222 75% OLM, unknown miles [Re: Ursatdx] #5388929 03/29/20 08:26 PM
Z
ZeeOSix Offline
Z
Been discussed many times. A bad ADBV on a vertically mounted filter with base up can still allow all the oil in the galleries above the filter to drain down.
Re: Service Champ OF2222 75% OLM, unknown miles [Re: ZeeOSix] #5389039 03/30/20 12:25 AM
O
oldhp Offline
O
.....and it doesn't take much to drain back down either. Just that second of pumped air will make'm tick.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Service Champ OF2222 75% OLM, unknown miles [Re: bullwinkle] #5389067 03/30/20 03:22 AM
GumbyJarvis Offline
Just ordered a case of 12 of these the other night for 8.99$/free shipping. LOL
shrug dont see a reason not to run these 12 filters at 5k mi, 3-6mo OCIs on my hemi.
2018 Ram 1500 5.7L SLT
Group 7 V2222 - Mobil 1 Truck & SUV 5w30
Re: Service Champ OF2222 75% OLM, unknown miles [Re: Ursatdx] #5389094 03/30/20 05:52 AM
B
B
Be well.
It had a Jiffy Lube sticker with QSAD 5W30 marked on it, for QS to be Dexos it needs to at least be the synthetic blend. The ADBV/combo valve wasn't hardened, but it was not completely flat, a little wavy. I have no way of telling if the oil was changed by the PO, but the filter did have the change date marked on it by JL.
Re: Service Champ OF2222 75% OLM, unknown miles [Re: kstanf150] #5389097 03/30/20 05:55 AM
B
B
It has 143K on it. I have a fair amount of RGT oil for it, it's going to get a few short OCIs with a couple Fram Extra Guards (with the newer silicone ADBV) to see if I can clean it up a little. I probably have some carbon & sludge I need to get out, but it runs as well as any 6.0 I've heard, doesn't even have the manifold tick (knock on wood).
Re: Service Champ OF2222 75% OLM, unknown miles [Re: GumbyJarvis] #5389099 03/30/20 05:57 AM
B
B
If you keep the interval down, and run some good oil, they will likely be fine. They are the smallest Ecores I've seen, though!
Re: Service Champ OF2222 75% OLM, unknown miles [Re: bullwinkle] #5389217 03/30/20 08:31 AM
53' Stude Offline
Bullwinkle: sounds like a good van so far smile
Re: Service Champ OF2222 75% OLM, unknown miles [Re: bullwinkle] #5389885 03/31/20 03:17 AM
GumbyJarvis Offline
Well my ebay seller refunded my money. Hes got this "he-who-not-be-named cough" illness thing and sent me a message saying that he wont be shipping anything or something. Weird.
I'd still run these filters in a clean engine. Shoot I'd run them in a dirty engine for a flush too.
Probably millions of quickie lube using negligent car owners going 10-15k on these running some bulk unnamed dyno.
