Post your latest oil change
2015 Mitsubishi Lancer ES, 4B11 [NA] @ 63,353 mi
Out: Pennzoil Platinum 0W-20, FRAM XG7317
In: Pennzoil Platinum 0W-20, Mobil 1 EP M1-110A
5,258 miles on oil/filter
Originally Posted by Triple_Se7en
Originally Posted by ptkdude
2012 Toyota Corolla, 1.8l
Out: Valvoline Maxlife 0W-20, Fram Ultra filter (94,088 miles)
In: Sunoco 0W-20, Genuine Toyota Filter (94,984 miles)
Changed after 2 months/900 miles due to cracked oil filter housing cap.
Any idea how that happened?
NTB doesn't use a torque wrench.
Lets see! Abbreviations / acronyms like NTB.
Forums / messageboards that almost always hold longer than normal conversations by communication toys and text-type small phones are not really intended / ideal, for this place, unless you spell-out the non-obvious words.
So, long-story-short, I have no idea what NTB means.
Perhaps we need a Sticky Thread on all the abbreviation-acronyms and have a List available to members here. I looked down the Thread Titles and didn't see one.
Originally Posted by Audioquest
2011 Toyota RAV4 2.5L AWD, 25,000kms
Out: Valvoline SynPower 5W20, Fram TG filter
In: Valvoline SynPower 5W20, Promotive Filter
Ever think about cutting the OCI in half?
2008 Acura TL in signature (117,011 miles)
Out -- Quaker State High Mileage Syn Blend 5W20 and Fram Ultra (3988 miles)
In -- Pennzoil Platinum Pure Plus High Mileage 0W20 and Fram Ultra
Fram Ultra that was removed was in use 3 oil changes with about 18 thousand miles overall.
2018 Toyota Tacoma
~34k, 4500k OCI on the Havoline pro DS 10w30. The miles went quick since December but I also had some heavy towing and a lot of city driving mixed in.
Just Dumped the pan no filter change this time leaving the K&N synthetic filter. Gasoline smelly oil but I didn't warm it up fully before draining, oh well probably do a uoa before the power train warranty is up.
In went 6 quarts of RTG 5w30.
I may dump and fill the 4 runner this afternoon. It has 5k on current fill but my wife uses it and it gets a lot of short trips of less than 5 miles.
2018 4 runner 17500 on vehicle ,I really love working on this one, higher gauge materials and extra things like the removable drain bolt cover on the skid plate. Even the drain plug is nicer than the one on my Tacoma.
Out went some dealer 0w20, filter kept in place. 5010 miles on the oil
In went 6 quarts of RTG 0w20. This sweetheart of an engine and the current duty expected makes me comfortable with the 0w20 at this time. If I start off-roading it again, or need to tow with it or it gets more high speed high temp highway driving I will revisit the viscosity, but I had this on hand so to get it another 5 k and through september it got used.
2007 Suburban 1500 LTZ 5.3
Out: AAP/Carquest 10W40 HM full syn/Mobil 1 oil filter. (Was having low oil pressure issues)
In: Mobil Super synthetic 10W30/ Fram XG10060 filter
Oil pressure and throttle response improved 25%
Dave
'08 Dodge Ram 3500 diesel
200911 miles total, 18000 on oil
Out: RT6 and Fram Ultra filter
In: RT6 and Fram Ultra filter
Oil sample taken.
2008 Ford F-150
199,864 miles - 4032 miles on oil
Out- Valvoline 5W30 Synthetic MaxLife, Motorcraft FL-820S filter
In- Valvoline 5W30 Synthetic MaxLife, Motorcraft FL-820S filter
2010 Kia Soul 2U, 2L, 153k miles
Out: Castrol Edge 5W-30; Fram TG9688
4K on oil and filter, 1.25 quart top off
In: Castrol GTX 5W-20; Motomaster MPH 9688 filter.
Bulk oil change at work while having other work done.
