Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
33 registered members (AndyB, ctechbob, daves87rs, DeafBrad, bbhero, 830Lee, 1 invisible), 1,450 guests, and 47 spiders.
Topics306,109
Posts5,286,657
Members71,586
Anyone here a blacksmith? #5388702 03/29/20 02:13 PM
53' Stude Offline OP
As many folks may or may not know, I enjoy the blacksmithing art or watching it being done. Is anyone here a blacksmith? Also, what actually is a quenching oil? I did google this and couldn't get a decent or proper answer.
Thank You kindly USA Canada
2009 Toyota Camry LE
Re: Anyone here a blacksmith? [Re: 53' Stude] #5388709 03/29/20 02:24 PM
spk2000 Offline
Quenching oil is to get more carbon into the steel to make it harder. Not a blacksmith but have an extensive metals background and have worked in 2 large steel mills among other metals manufacturing environments.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Anyone here a blacksmith? [Re: spk2000] #5388718 03/29/20 02:38 PM
Thanks for the info. Some searching I did says possibly a vegetable oil. Anybody know what oil is used for quenching?
Re: Anyone here a blacksmith? [Re: 53' Stude] #5388719 03/29/20 02:40 PM
spasm3 Online Happy
Online Happy
Would used motor oil work? Should have more carbon.
Just make sure it's not from a gdi engine! grin2
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Anyone here a blacksmith? [Re: 53' Stude] #5388864 03/29/20 06:58 PM
BlueOvalFitter Offline
Peanut oil and Canola oil.
https://www.knifepath.com/best-oil-quenching-steel/
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Anyone here a blacksmith? [Re: 53' Stude] #5388879 03/29/20 07:18 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I've evaluated quenched and tempered product for 40 years and I've never heard of steel picking up carbon from the quench. I dont know where people get that from. It just doesn't happen.
Oil is used to reduce the quench severity, because water can sometimes crack the part. Used motor oil should work okay for backyard quenching. Just make sure the water content is low.
Re: Anyone here a blacksmith? [Re: Kestas] #5388889 03/29/20 07:26 PM
4WD Offline
Yeah … physics did not change circa Twitter … that’s how we made homemade chisels when I was in High School
(around the time iron was first discovered 😎)
Re: Anyone here a blacksmith? [Re: 53' Stude] #5388918 03/29/20 08:12 PM
Dinoburner Offline
The machine shop I worked in almost 60 years ago water quenched and tempered some parts including small v notched knives. The company engineer wanted to try oil quenching and had some success. the blacksmith stuck with water as his knives would cut more glue tape than the oil quench. A comment was made that if the knives were oil quenched after sharpening some carbon would be embeded in the steel. Most heat treating was checked for hardness but not the knives.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Anyone here a blacksmith? [Re: 53' Stude] #5388923 03/29/20 08:20 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Whoever made that comment didn't know what they were talking about. Chalk it up to myth or old wives tale.
Re: Anyone here a blacksmith? [Re: spasm3] #5388931 03/29/20 08:29 PM
Z
ZeeOSix Offline
Z
eek LOL
Re: Anyone here a blacksmith? [Re: Kestas] #5388933 03/29/20 08:31 PM
Yeah, quenching steel or iron in water is let's just say not wise at all. Somedays I seriously just shake my head
Re: Anyone here a blacksmith? [Re: 53' Stude] #5388991 03/29/20 09:52 PM
samven Offline
It depends on the steel and what you want to end up with, if you are using an O type steel the O stands for oil quench, if your using an
A steel it is Air Quenching. If you use water you will get a harder finish but if you use a fine grained steel and water quench you stand a good chance of cracking it.
If you want to anneal it quench in sand.
Re: Anyone here a blacksmith? [Re: 53' Stude] #5389016 03/29/20 10:47 PM
Dinoburner Offline
When heat treating a cold chisel I use the water method followed by annealing also in water. Been using this method since 1959.
Kubota L5030 T6
