Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
20 registered members (A_Privateer, Char Baby, blufeb95, ArrestMeRedZ, carlprop, chemman, 2 invisible), 1,274 guests, and 55 spiders.
Topics306,079
Posts5,286,953
Members71,596
XG10575 Walmart.com deal #5388624 03/29/20 12:29 PM
7
762fermeandyou Offline OP
7
Walmart website has XG10575 (common for Ford and Chevy) for $5.80/1 better deal for 2 to 12. $35 spend for free shipping
62 Mercury Meteor 5.0 10w30 VPB blend / FL1A
95 Jeep ZJ 4.0 5w30 Havoline Conv / Rislone ZDDP / XG8A
15 Silverado 5.3 0w20 QSUD / PF63E
17 Explorer 3.5 N/A 5w20 Napa syn / Napa Proformer
Re: XG10575 Walmart.com deal [Re: 762fermeandyou] #5388800 03/29/20 05:00 PM
blupupher Offline
Looks like it would fit my F150 (standard is a PH2 size).
Same thread, almost identical gasket size, a little taller but a little smaller diameter (which I want since the PH2 is kind of hard to fit in place), but a high bypass pressure (XG2 is 12 psi, the XG10575 is 16-28 psi).
Not a bad deal though if it fits your vehicle.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/ProGuard
'12 xB: M1 EP 0W-20/CQ Blue
'10 Santa Fe: Synpower 5W-30/D+
'04 F150: Magnatec 10W-30/ST
'02 F150: PP 0W-20/M1
'94 VT1100: Peak 15W-40/Wix
Re: XG10575 Walmart.com deal [Re: 762fermeandyou] #5388832 03/29/20 06:04 PM
4WD Offline
Yes … Motorcraft FL500s or Albert Champion Delco PF63 …
Re: XG10575 Walmart.com deal [Re: 762fermeandyou] #5388935 03/29/20 08:33 PM
G
GMguy84 Offline
G
hmmmm....So would this fit my vic that uses a XG2 filter ???
Will the higher bypass pressure affect anything ??
Dave
01 Silverado 1500HD Shell RGT 5W30/XG3675
07 Suburban 1500 Mobil Super Syn 10W30/XG10060
82 Trans Am (KITT) M1 10W40HM/XG5
Re: XG10575 Walmart.com deal [Re: GMguy84] #5388970 03/29/20 09:19 PM
53' Stude Offline
Dave
Probably fit fine. The plow truck of ours had fl820S size filters on them, we use 10575 interchange to auto extra # without issue.
2009 Toyota Camry LE
Re: XG10575 Walmart.com deal [Re: 53' Stude] #5389182 03/30/20 07:54 AM
G
GMguy84 Offline
G
Dave
Thanks Adam for the confirmation thumbsup
Looks like ill be stopping by Walmart today and picking one up !!! Just can't beat a XG filter for $6 banana
Dave
Re: XG10575 Walmart.com deal [Re: 762fermeandyou] #5389285 03/30/20 09:28 AM
blupupher Offline
They have, single, 2, 4, , and 12 packs of this filter. Price gets cheaper per filter the more you buy (not by much though)
https://www.walmart.com/search/?query=XG10575
and of course Amazon has matched the price for the single.
https://www.amazon.com/dp/B006DXWZQU?
