98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
103 registered members (10WSmuckers, 50jeffrey, Alfred_B, 928, alchargo, 53' Stude, 8 invisible), 2,811 guests, and 77 spiders.
Topics305,905
Posts5,282,551
Members71,535
1990 Toyota 4x4 transmission fluid type #5387912 03/28/20 01:08 PM
R
R1jake Offline OP
R
I am trying to figure out if my 1990 Toyota 4x4 22r manual transmission (my baby) has any yellow metals in the transmission or transfer case?? While researching I keep seeing everyone pretty much recommend a GL-5 80/90 in the diffs. For the manual transmission and t case I keep seeing GL-4 or GL-5. Back when I had my 00 Volkswagen GTI I couldn’t use a gl-5 due to it having yellow metals in the manual transmission. So I want to make sure this is not the case on my truck. While researching I have found one person mention yellow metals in the transmission of my truck. Not sure if this is true?? Everyone else is saying GL-4 or GL-5 80-90
I figured this is the place for the correct answer and hope you all can help.
Yamaha R1 5vy
94 Ford E150
09 Pontiac vibe AKA Toyota Matrix
02 dodge neon my winter car, refuse to drive my van in the salt.
Re: 1990 Toyota 4x4 transmission fluid type [Re: R1jake] #5387946 03/28/20 01:41 PM
B
bronx Offline
B
I used redline MT-90 in my 2008 Tacoma 5 speed manual for years without issue. I sure it will work great in your transmission and transfer case.
https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil
Re: 1990 Toyota 4x4 transmission fluid type [Re: R1jake] #5387950 03/28/20 01:47 PM
K
kschachn Online Content
Online Content
K
The place for the correct answer is your owner's manual. What does it say?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: 1990 Toyota 4x4 transmission fluid type [Re: R1jake] #5387995 03/28/20 02:50 PM
CT8 Offline
i used MT 90 in my 92 and 06 4X4s Tacomas manual transmissions
2015 F150 2.7
2018 F350 6.2
Re: 1990 Toyota 4x4 transmission fluid type [Re: kschachn] #5388003 03/28/20 02:56 PM
R
R1jake Offline OP
R
This I do not have, which is very weird I have everything else including the original window sticker. Somewhere along the line the manual is missing.
Yamaha R1 5vy
94 Ford E150
Re: 1990 Toyota 4x4 transmission fluid type [Re: CT8] #5388007 03/28/20 02:57 PM
R
R1jake Offline OP
R
This is what I was thinking, or possibly amsoils gl-4.
Yamaha R1 5vy
94 Ford E150
Re: 1990 Toyota 4x4 transmission fluid type [Re: R1jake] #5388008 03/28/20 02:58 PM
R
R1jake Offline OP
R
Does anyone know if there are any yellow metals in the manual transmission?? Or the t case??
Yamaha R1 5vy
94 Ford E150
Re: 1990 Toyota 4x4 transmission fluid type [Re: R1jake] #5388225 03/28/20 07:03 PM
Z
zeng Offline
Z
Typically manual transmission has yellow metal synchronisers (say 90ish % if not 100 IME , no evidence or proof though), not yellow metal gears or journal bearings etc .
I'm very confident this yota manual transmission has yellow metal synchronisers . Tcase I'm not so sure as some may not have yellow metals .
GL4 is about 'smooth shift' .Period. Though GL5 (often friction reducing) of similar viscosity grade typically offers higher MOFT and gears/bearings components protection .
If 'smooth shift' is of no concern to one, by all means carry on with a GL5 IMO .
Re: 1990 Toyota 4x4 transmission fluid type [Re: zeng] #5388730 03/29/20 03:00 PM
R
R1jake Offline OP
R
I am definitely going to go with GL-4 in the transmission and t case as well I suppose.
Yamaha R1 5vy
94 Ford E150
Re: 1990 Toyota 4x4 transmission fluid type [Re: R1jake] #5388865 03/29/20 07:00 PM
K
Kamele0N Offline
K
https://www.bobistheoilguy.com/foru...0f-need-help-choosing-mt-oil#Post5282140
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
