TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
14 registered members (Char Baby, bbhero, 2015Corolla, AnthemBassMan, daves87rs, ctechbob, 2 invisible), 1,151 guests, and 24 spiders.
Topics306,033
Posts5,285,251
Members71,566
Jacking the rear of 98 mustang question #5387836 03/28/20 11:26 AM
old1 Offline OP
As the title says, I am curious about how to safely jack the rear of my 98 mustang, which is new to me. The owners manual that came with the car, says in BOLD letters, to NOT jack the rear of the car from the center of the differential. It does not of course say why. I asked on a mustang forum, and was told that the manual was probably referring to using the factory tire changing jack, as it could fall off too easily. I think that it looks like that the parts are solid and strong enough to lift from the center, but want to see what everybody here thinks, before I use my floor jack and mess up something. I usually (on other cars) just jack up with the jack under the differential, and then put jack stands under the outer ends of the axles.
As a side note, my 65 mustang also says that, but everybody I have spoken to, and myself, do it that way, and never a problem.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 FOR SALE
1998 Mustang 3.8 automatic 78K miles
Re: Jacking the rear of 98 mustang question [Re: old1] #5387838 03/28/20 11:30 AM
dwcopple Offline
use the torque box areas to lift it and use a jackstand on the axle shafts
2019 RAM Big Horn 4x4 Blackout HEMI crew cab
2011 Chrysler 200 Limited 3.6L V6
1998 Mustang GT 4.6L V8 convertible
2019 VW Jetta SEL 1.4T
Re: Jacking the rear of 98 mustang question [Re: old1] #5387851 03/28/20 11:41 AM
bdcardinal Offline
They say that because it could possibly change the pinion angle. That being said I usually use the pumpkin to lift mine, or to be more accurate lift when on 4 stands so I can remove the rear 2.
EDIT: I had a 98 GT with a bunch of Maximum Motorsports parts including the full length subframe connectors so I could lift it all all sorts of ways.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Jacking the rear of 98 mustang question [Re: old1] #5387867 03/28/20 11:58 AM
T
tcp71 Offline
T
The axle shafts are press fit into the differential housing. It is possible to shift their alignment. Use a jack near the spring mount u-bolts On each side individually, then support each with a jack stand under the tube near the springs.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Jacking the rear of 98 mustang question [Re: tcp71] #5387899 03/28/20 12:38 PM
bdcardinal Offline
The springs don't mount to the differential on a 98 Mustang. They mount to the lower control arm, assuming it is still a factory configuration.
Re: Jacking the rear of 98 mustang question [Re: old1] #5387903 03/28/20 12:44 PM
G
GMBoy Offline
G
Use the mounting points on the body and then place jack stands for the safest way.
Re: Jacking the rear of 98 mustang question [Re: old1] #5387925 03/28/20 01:24 PM
B
Black_Thunder Offline
B
seeing that its a straight axle on this model mustang, I see no problem with jacking up under the diff housing, I then put stands under each side of the axle right on the tubes by the shocks etc so it sits level and sturdy and then you can remove the jack and give you room to work underneath it etc.
I'd buy Callahan autoparts if I could.
Re: Jacking the rear of 98 mustang question [Re: bdcardinal] #5387933 03/28/20 01:30 PM
A
atikovi Offline
A
"the owners manual that came with the car, says in BOLD letters, to NOT jack the rear of the car from the center of the differential." so you are suggesting he can do exactly that?
Re: Jacking the rear of 98 mustang question [Re: atikovi] #5388021 03/28/20 03:08 PM
bdcardinal Offline
I am saying that I have done it many times fully knowing the consequences of my actions. But I also usually wear shorts and flip flops working on my cars so I obviously run a safety first operation.
Re: Jacking the rear of 98 mustang question [Re: old1] #5388254 03/28/20 07:37 PM
L
LotI Offline
L
My E450 with a Dana rear end states the same in the manual. Might just be a Ford thing
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
19 Buick Regal TourX
Re: Jacking the rear of 98 mustang question [Re: old1] #5388264 03/28/20 08:03 PM
B
buck91 Offline
B
Been jacking the rear of multiple 8.8 dif vehicles for many years without complication.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Jacking the rear of 98 mustang question [Re: bdcardinal] #5388280 03/28/20 08:32 PM
E
earlyre Offline
E
you sure you're not secretly David Freiburger?
Mine:
13 Ford C-MAX hybrid: Bulk Maxlife Full Syn 5w20,& Valvoline Jobber Filter
( I was Lazy and had a Groupon)
