I am working on a front Brembo caliper from a 2004 Subaru WRX STI. Upon removing the upper caliper bolt, the threads were damaged inside of the aluminum caliper. Supposedly this is a somewhat common issue on the early STI's due to a combination of galvanic corrosion and overtorquing. The threads are M12x1.5.
This was my first experience with using a Timesert and I am not the best at drilling. As instructed, I drilled out the damaged threads, drilled the counterbore, tapped new threads (for the insert) and installed the Timesert using the supplied tool. I used a few drops of Permatex orange before installing the insert. Pictures are below.
My concern is that my counterbore does not appear to be 100% straight. About 1/2 of the counterbore is probably 0.25mm-0.5mm deeper than the other half. However, when I tapped threads for the insert, I used a tap guide and those threads appear to be 100% straight. Based on my understanding of the counterbore's function, I think the counterbore is just a retainer for the lip on the Timesert.
So, will this work?
So, will this work?
