I am keeping myself busy with the shutdown.
My 2hp honda outboard was left all winter with gas in it and let's just say, the jets are clogged and probably the float pin ...
I tried draining the old gas and added sea foam and fresh gas, no dice,
What is a good strong carb cleaner I use?
The plan is to drain the carb and the tank and add a little fresh gas and carb cleaner and let it sit. I am trying to avoid taking the carb apart
