Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Jcvjr, Haywood, ToOliwer, AbbeyRoad, RPF
71587 Registered Users
22 registered members (Astro14, dlundblad, cbrf23, Cdn17Sport6MT, 53' Stude, ctechbob, 1 invisible), 1,176 guests, and 39 spiders.
Topics306,109
Posts5,286,667
Members71,587
Carb cleaner safe on plastics/rubber #5387714 03/28/20 09:20 AM
stockrex Offline OP
I am keeping myself busy with the shutdown.
My 2hp honda outboard was left all winter with gas in it and let's just say, the jets are clogged and probably the float pin ...
I tried draining the old gas and added sea foam and fresh gas, no dice,
What is a good strong carb cleaner I use?
The plan is to drain the carb and the tank and add a little fresh gas and carb cleaner and let it sit. I am trying to avoid taking the carb apart
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: Carb cleaner safe on plastics/rubber [Re: stockrex] #5387717 03/28/20 09:24 AM
B
Brian123 Offline
B
I had a problem like yours and took the carburetor off and soaked it in MMO for a few hours. Its been running fine, you could also just put a new carburetor on.
Re: Carb cleaner safe on plastics/rubber [Re: stockrex] #5387729 03/28/20 09:33 AM
dave123 Offline
Might try VPracing Fix it Fuel
Re: Carb cleaner safe on plastics/rubber [Re: stockrex] #5387772 03/28/20 10:26 AM
F
FT92 Offline
F
like above, MMO is what i use ,,have had good luck with the stuff
Re: Carb cleaner safe on plastics/rubber [Re: stockrex] #5387773 03/28/20 10:29 AM
O
Olas Offline
O
Berrymans
Re: Carb cleaner safe on plastics/rubber [Re: stockrex] #5387872 03/28/20 12:02 PM
U
Ursatdx Offline
U
Soak and use compressed air.
There are very small ports that will block easily.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Carb cleaner safe on plastics/rubber [Re: Olas] #5387873 03/28/20 12:04 PM
T
Trav Offline
T
+1 Drain the carb and fill it with the berrymans, let it dwell for 30 min or so.
https://www.amazon.com/Berryman-Chemtool-Carburetor-Injector-Cleaner/dp/B000CCMNAG
Re: Carb cleaner safe on plastics/rubber [Re: stockrex] #5387984 03/28/20 02:39 PM
B
Brybo86 Offline
B
Take off the carb spray carb cleaner into holes where jets go, especially the pilot or low speed jet
You can prolly leave the top of carb on if it has one
If a passage is 100%clogged , spraying something isn't going to open it up
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: Carb cleaner safe on plastics/rubber [Re: Brian123] #5389055 03/30/20 02:08 AM
M
Mad_Hatter Offline
M
The MMO soak would work but he's trying to avoid taking it off. hit it hard a couple of times with a can of carb cleaner/CRC/Berryman's.. then run a tank of B12+ fuel to finish off the cleaning. I have to do this same thing to my old Toro every couple of years..
