Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
101 registered members (1978elcamino, 762fermeandyou, 2015_PSD, ArrestMeRedZ, 2004tdigls, 10 invisible), 2,678 guests, and 57 spiders.
Topics305,904
Posts5,282,485
Members71,535
Toolbox corrosion protection #5387432 03/27/20 09:39 PM
B
buck91 Offline OP
B
So I recently upgraded my tool chest from multiple boxes and a small chest into one large, almost organized chest. I typically wipe my tools down with either a lightly oiled rag or occasionally a fluid film rag when they are dirty and don't typically have corrosion issues, but with the change I not have many tools inside the chest/drawers/cabinet that typically were sitting on a shelf in their box. As these spaces are enclosed but not sealed I don't think desiccants will offer much benefit but not sure if its really worth the effort to go further with any other options. Not really sure what other options there would be other than that vapor corrosion inhibitor... but I don't know much of anything about that.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Toolbox corrosion protection [Re: buck91] #5387438 03/27/20 09:42 PM
Astro14 Offline
Any chance you can dehumidify the whole space?
For example: https://www.lowes.com/pd/Hisense-70...ith-Built-In-Pump-ENERGY-STAR/1000731818
This is in my shop right now, and it pumps out quite a bit of water every day. The inside of the shop is between 40 and 50% RH, which should keep everything from rusting.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Toolbox corrosion protection [Re: buck91] #5387440 03/27/20 09:44 PM
clinebarger Offline
I use VCI paper, Works very well. Grainger sells Armor Wrap VCI paper.
2001 Chevy Camaro L92/4L80E
Re: Toolbox corrosion protection [Re: buck91] #5387451 03/27/20 09:56 PM
samven Offline
CRC marine corrosion inhibitor. Spray on, dries to the touch and wont wash off even with a pressure washer. Protects against salt water like sweat or sea air. I use it on tools in the barn and reapply in the fall just to be sure but so far it works well.
Re: Toolbox corrosion protection [Re: buck91] #5387558 03/28/20 05:36 AM
demarpaint Offline
I wipe my tools down with a light coat of oil before putting them away.
God Bless Our Troops
Re: Toolbox corrosion protection [Re: demarpaint] #5387582 03/28/20 06:54 AM
Astro14 Offline
Me too.
I use Liquid Wrench spray oil. Or Remoil. A spritz and a wipe.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Toolbox corrosion protection [Re: buck91] #5387590 03/28/20 07:08 AM
4WD Offline
For tools in my large roll around … spray wax … for vice grips and adjustable wrenches … a drop of 3 in 1 …
After the loss of several tools in my boat box … went to several smaller sealed boxes with no handles (source of water ingress). After the re-do … I used Rust Block on them … decent water based product
Re: Toolbox corrosion protection [Re: samven] #5387613 03/28/20 07:38 AM
R
Railrust Offline
R
I’ve been dying to try this stuff for my frame, hear it works great. Think I’ll order some today.
2018 Chevy Silverado 5.3
2007 Lexus LS460 (deceased)
2008 Honda CRV
(Whatever synthetic oil is on sale or rebate)
Re: Toolbox corrosion protection [Re: buck91] #5387659 03/28/20 08:22 AM
E
eljefino Offline
E
I use dessicants, got a 50 pack of silica gel on ebay and scattered them through.
The tools in my drawers do better than the ones left out.
My unheated, uninsulated garage spends a lot of time near the freezing point-- the concrete floor holds the cold and causes condensation.
I'm too cheap to do any sort of climate control in there.
If a tool gets oily, I wipe it down, but not necessarily wipe it off.
Re: Toolbox corrosion protection [Re: buck91] #5387661 03/28/20 08:24 AM
Cujet Online Content
Online Content
Could also put a 60 watt light bulb in the bottom and cover the box with a fabric/vinyl cover.
Condensation due to temperature changes is a driving factor behind corrosion. If your box is in a location where the tools are cold in the AM and temperature/humidity increases, that's a perfect situation for condensed moisture to form on tools. By keeping the metal slightly warmer, condensation won't form.
[Linked Image from matcotools.com]
A favorite product to prevent corrosion: Corrosion technologies "Max Wax". It's wonderful when applied in a very thin coating. It truly is better than the others.
https://www.corrosionx.com/products/maxwax-tough-long-lasting-wax-coating
Re: Toolbox corrosion protection [Re: samven] #5387664 03/28/20 08:28 AM
4WD Offline
A while back … we had a thread in all the great products 3M makes (some in big demand now).
CRC is another great brand. Always my go to for throttle bodies and battery terminals
For my boat I use Corrosion-X … but it’s too thick and waxy for some things … got to try this CRC product …
Just ordered from Walmart
Re: Toolbox corrosion protection [Re: buck91] #5387825 03/28/20 11:17 AM
samven Offline
If your going to do big jobs like a frame or keep it on the boat for under the cowling and other bright work you can get it in 4 packs for $30 so it works out to 7.50 a can. Put it on thin and let it dry. If you really need lots of abuse protection or inside box frames I tend to go a bit heavy but not in areas where I will bump into it or handle it. If you use a thin coat it wont attract dirt and it doubles as a lube so a bit of overspray on the suspension or steering linkage wont hurt anything, just keep it away from disk rotors or pads. I spray it on a rag to wipe down my bandsaw table and blade and the table and column on my lathe and mill.
Re: Toolbox corrosion protection [Re: buck91] #5387876 03/28/20 12:07 PM
B
bsmithwins Offline
B
For storage BoeShield liquid dries to leave a waxy film and has antirust additives. For extra protection Zerust makes plastic bags impregnated with antirust additives that out gas slowly. The plastic come in ziplock bags, open bags for heat sealing, and in sheets.
BSW
Re: Toolbox corrosion protection [Re: buck91] #5388199 03/28/20 06:24 PM
H
HangFire Offline
H
For the tool chest itself, remove the drawers and spray the insides with Fluid Film, Boeshield, or the like. Flip it over and spray the bottom, too.
Put Camphor blocks or the CI paper in the drawers.
Refresh as needed and you'll be set.
Various musings: http://hangfire.net
