Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
37 registered members (bachman, ArrestMeRedZ, AndyB, ctechbob, bbhero, 830Lee), 1,323 guests, and 51 spiders.
Topics306,109
Posts5,286,659
Members71,586
Transmission Problem #5387551 03/28/20 04:59 AM
R
RoGuE Offline OP
R
I just purchased a 2001 Corvette on Monday. It has 144k miles, 5.7L, and an automatic. I test drove it twice, and drove it home nearly 70 miles. I parked it in my garage for a day and came then drove it on Wednesday morning. As soon as I get to a highway about a mile from my home, the transmission will not shift past second gear. When it is supposed to go in to third gear, it feel like the engine and trans disconnect like I shifted in to neutral. The engine will just rev high and then it will catch back on to second gear rather violently.
I assume the transmission is done and will need a rebuild which saddens me as I wasn't really planning for it and did not detect any transmission issue before purchase. From my understanding this is not an uncommon issue with stock 4L60E transmissions burning up a clutch pack prevent 3rd gear and up. There are no transmission related codes (used OBD2 scanner with Torque app and the built in instrument panel DIC code reader). The only thing I can see visible is a cracked neutral safety switch/range selector. From what I've read, that wouldn't cause the issues I have.
https://www.youtube.com/watch?v=ItwCvpVyOjw
Anything in particular I can check to verify if this needs to be replaced?
2007 Chevrolet Malibu
2.2L Ecotec
Re: Transmission Problem [Re: RoGuE] #5387557 03/28/20 05:17 AM
O
Olas Offline
O
just fit a manual.
Re: Transmission Problem [Re: RoGuE] #5387564 03/28/20 05:52 AM
skyactiv Offline
BE SURE to have a heavy duty sun shell installed while it's being rebuilt.
https://www.monstertransmission.com/700R4-4L60E-4L65E-Heavy-Duty-Sunshell_p_4875.html
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Transmission Problem [Re: RoGuE] #5387761 03/28/20 10:17 AM
bdcardinal Offline
I think the hardest part of the whole thing will be pulling the transmission since it is rear mounted on that C5.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Transmission Problem [Re: RoGuE] #5387795 03/28/20 10:47 AM
A
Audios Offline
A
Can you check the fluid level? Also it may be a computer issue, try disconnecting the battery for a bit. If no change scan to see what it says.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Transmission Problem [Re: RoGuE] #5387880 03/28/20 12:13 PM
T
tcp71 Offline
T
Check the fluid level before deciding it’s done.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Transmission Problem [Re: RoGuE] #5387891 03/28/20 12:26 PM
69GTX Offline
I'd add remove some fluid and put a bottle of Lubeguard red in there. What's to lose? If the fluid looks dark and dirty, change as much as you can as the viscosity will be quite low. Is the right fluid in there to begin with?
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Transmission Problem [Re: RoGuE] #5387930 03/28/20 01:27 PM
caprice_2nv Offline
Seems a little weird that it would go from shifting fine to no gears at all. A friend of mine with a higher mileage Sierra with the 4L60E just put a rebuilt in after putting up with it slipping into 3rd when he towed his trailer for a few months. It never actually failed. There is still a possibility something let go though. Just be sure before a full rebuild.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: Transmission Problem [Re: caprice_2nv] #5388187 03/28/20 06:04 PM
R
RoGuE Offline OP
R
I put the car up on jackstands keeping it level. Let the transmission warm up to 100-120 degrees. Pulled the plug and nothing dribbled out. Added about 1.5 qts while running until it started to come out and test drove. It made no difference. Any other ideas?
It has gears...just the first 2.
2.2L Ecotec
Re: Transmission Problem [Re: RoGuE] #5388309 03/28/20 09:37 PM
clinebarger Offline
The 3-4 Clutches are burnt down, Nothing short of a rebuild will fix it!
It doesn't technically neutralize, Once the 2-4 Band gets push off....The 3-4 Clutch is suppose to come on for a 2-3 shift. If the 3-4's are smoked, Your now back in 1st gear, But the road speed is too high & the Forward Sprag is overunning.
STOP banging against the Forward Sprag as it can break & take out the sprag race & input drum.
2001 Chevy Camaro L92/4L80E
Re: Transmission Problem [Re: Olas] #5388331 03/28/20 11:06 PM
J
john_pifer Offline
J
Originally Posted by Olas
just fit a manual.
Yep. This is your chance.
Swap in a manual, like the car was intended for.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 228K
18 Civic HB 1.5T 6MT (Wife's) - PPPP 10W-30, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Transmission Problem [Re: john_pifer] #5388386 03/29/20 03:47 AM
A
AC1DD Offline
A
I never am surprised how people will buy things like this junk and they get hosed. smirk2
Re: Transmission Problem [Re: AC1DD] #5388450 03/29/20 08:24 AM
caprice_2nv Offline
How was he supposed to foresee this happening if it was fine on 2 test drives? Lots of 4L60E transmissions last over 300k miles. Unfortunately, not all of them do. Sounds like bad luck to me, unless the seller knew it had a problem and dumped a bunch of Lucas in it to get it down the road.
79 Honda CX500
Re: Transmission Problem [Re: RoGuE] #5388704 03/29/20 02:16 PM
R
RoGuE Offline OP
R
just fit a manual.
Not an option for me. I prefer the automatic.
Right, because it wasn't shifting great for 20 miles of test driving and then perfect at 75 mph on the 70 mile drive home. There was no transmission leak under the car, and the temps were great. Thanks for the helpful response.
Bad luck it is...
I will make some calls to transmission shops near me. How much should I be expecting to pay for a job like this?
2.2L Ecotec
Re: Transmission Problem [Re: RoGuE] #5389202 03/30/20 08:16 AM
supton Offline
Any value in a different gearset for this transmission? I'm guessing it's not cheap but I think Sonnax has a 2.8 first gear option. It's a Vette and doesn't need a wide set of gears.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
