Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
20 registered members (blufeb95, dishdude, GMguy84, FTL, Cdn17Sport6MT, JEL01, 1 invisible), 1,319 guests, and 37 spiders.
Topics306,109
Posts5,286,660
Members71,586
Milwaukee 2767-20 Impact Wrench #5387431 03/27/20 09:38 PM
W
Wolf359 Offline OP
W
Only a little time left today.
Not as good as the last time but $211.65 for the impact wrench and the 4 amp hour battery instead of the 5. I plan to use mine on some anode rods. It's 1400 foot pounds of loosening torque.
https://slickdeals.net/f/13941863-m...attery-pack-bundle-zoro-211-65-with-code
Re: Milwaukee 2767-20 Impact Wrench [Re: Wolf359] #5387469 03/27/20 10:34 PM
Donald Offline
I would get the one that is labeled "high torque".
Note no charger.
2015 Ford F-250 w/Powerstroke
Re: Milwaukee 2767-20 Impact Wrench [Re: Wolf359] #5387483 03/27/20 11:05 PM
c502cid Offline
That last deal was swinging. I bought the charger and another 5 amp/hr battery from Amazon for under $90, I absolutely love this impact!
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: Milwaukee 2767-20 Impact Wrench [Re: Donald] #5387489 03/27/20 11:24 PM
W
Wolf359 Offline OP
W
Note no charger.
Yes, this is the high torque one, 2767-20. I'm debating whether to get the charger for $32 on Amazon or the 5 amp hour battery plus charger for $86. Regular 5 amp hour battery is $62 on Amazon. Or wait for some other deal with the battery/charger and some other tool.
Re: Milwaukee 2767-20 Impact Wrench [Re: Wolf359] #5391835 04/02/20 12:21 PM
I
Ihatetochangeoil Offline
I
Buy once, cry once.
I've had this tool for about a year now. Wish I'd had it 10-20 years ago. Lug nuts are small potatoes. Control arm bolts or strut bolts no sweat. Loosened a crank bolt for a harmonic balancer replacement using torque level 2 (out of 4). I honestly can't think of ANYTHING (on an automobile) that wouldn't break loose with 1400 ft lbs of breakaway torque; if you've got clearance to get the wrench on it, it's coming off. I actually carry this thing around with me in my cars trunk now. It's flat out awesome. No compressor or cords needed. https://www.milwaukeetool.com/Products/Power-Tools/Fastening/Impact-Wrenches/2767-20
Re: Milwaukee 2767-20 Impact Wrench [Re: Wolf359] #5391972 04/02/20 03:44 PM
W
Wolf359 Offline OP
W
I'm going to try it on some water heater anode rods. I had to use an 18 inch breaker bar with a 3 foot pipe extension to break those free with 2 people. We'll see how 1400 foot pounds do.
Re: Milwaukee 2767-20 Impact Wrench [Re: Wolf359] #5392069 04/02/20 06:15 PM
U
user52165 Offline
U
Not sure what water heater you were working on, but that kind of force would normally break a home unit, or break it's mounting. Some penetrant first would be good.
It's not the brute force of "1400 ft/lbs" (sic) as much as it is the hammer action of quick impacts that will make it work for you.
I have a Milwaukee 2860 rated 450/600 ft/lbs which will take off any car fastener including crank bolts.
Re: Milwaukee 2767-20 Impact Wrench [Re: user52165] #5392086 04/02/20 06:41 PM
W
Wolf359 Offline OP
W
Yeah, that was with some Kroil first and it still took the 3 foot pipe to loosen them. Did 8 water heaters, 4 came loose with the 18 inch bar, the other 4 needed the 3 foot bar. But it was still a bear. They were all fine afterwards. They were already at the 4-7 year mark so I was ok with breaking a water heater anyway, but they were all fine. That was years ago and now I'm hoping I can just do it with a 2 man crew instead of 3. Making one last another 5-6 years easily pays for this impact wrench.
