Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
33 registered members (bbhero, daves87rs, 830Lee, Ag76, DeafBrad, Chris142, 1 invisible), 1,498 guests, and 33 spiders.
Topics306,109
Posts5,286,654
Members71,586
Short article about the origins of the side post battery. #5387409 03/27/20 09:17 PM
A
atikovi Offline OP
A
Re: Short article about the origins of the side post battery. [Re: atikovi] #5387492 03/27/20 11:31 PM
Driz Offline
Ahhhh, Twas another reinvention of the wheel it was. I hated the things the first time I tried to jump a frozen car way back then. Guess what , whenever I touch the one on my truck today it still irks me. They must not be anything special because nobody ever seemed to use that style except a GM.
My own thought on their purpose was nothing but $$$$$$$. Just a way to make an unusual style battery because they made their own at the time and hopefully make more on replacements. Just another reinvention of the wheel nothing more.
Re: Short article about the origins of the side post battery. [Re: atikovi] #5387617 03/28/20 07:39 AM
W
wag123 Offline
W
It was my understanding that the sealed side terminal battery was invented by GM/Delco because of the Chevy Vega which was shipped from the factory standing on end vertically in rail cars. I'm not sure why GM decided to use them in all of their vehicles. Perhaps they were cheaper to manufacture, or maybe they were toying with the idea of shipping other vehicle models this way..
Re: Short article about the origins of the side post battery. [Re: atikovi] #5387622 03/28/20 07:43 AM
L
Lapham3 Offline
L
I just skimmed this story, but our new '72 Vega GT was delivered by specially designed rail cars where the cars were loaded in nearly a vertical nose down position. There was mention back then that using the new sealed battery was necessary for this delivery system. I've had/have these batteries in quite a number of GM vehicles over the years and have had no particular problems with them even as I know that terminal corrosion has been an issue for many others. I do pay attention to the sealing areas for any debris and use some dielectric grease to keep moisture out.
Re: Short article about the origins of the side post battery. [Re: atikovi] #5387652 03/28/20 08:17 AM
E
eljefino Offline
E
They were a good setup, though the stock 5/16" bolt heads sucked for jump starting. Noone used the U-shaped adapters on jumper cables, or knew that they slid into that round slot.
The Plymouth Breeze used this battery style, too, IIRC, and buried it deep in the fender liner.
Re: Short article about the origins of the side post battery. [Re: atikovi] #5387692 03/28/20 08:59 AM
K
Kira Offline
K
Thank Heavens that article was as short as it was. Whatta buncha empty fluff....kind of like listening to a description of Crypto-currency.
"Other advantages...are improved under-hood appearance and foolproof terminal connections during installation."
Don't let the General do you any favors.
QUESTION: Who got the credit for designing the near vertical Vega delivery rain cars? We'll never see a Lionel version of that one.
Re: Short article about the origins of the side post battery. [Re: Kira] #5387699 03/28/20 09:07 AM
A
atikovi Offline OP
A
I want to see pictures of that.
Re: Short article about the origins of the side post battery. [Re: atikovi] #5387724 03/28/20 09:29 AM
M
mk378 Offline
M
Even though Delco invented the side-terminal battery, their manufactured side terminal batteries were notorious for leaking acid at the terminals. It took third-party manufacturers to solve that.
Re: Short article about the origins of the side post battery. [Re: atikovi] #5387743 03/28/20 09:53 AM
F
Fitter30 Offline
F
Never knew vega's were shipped vertically.
Re: Short article about the origins of the side post battery. [Re: atikovi] #5387752 03/28/20 10:05 AM
H
Highboy Offline
H
[Linked Image]
2006 Scion tC ST/Oem filter
2008 Scion tC ST/Oem filter
2008 Toyota Highlander Pennzoil Ultra/ Oem filter
2019 Subaru WRX
Re: Short article about the origins of the side post battery. [Re: atikovi] #5387936 03/28/20 01:33 PM
A
atikovi Offline OP
A
That's insane. Are they resting on the front bumpers or hanging by the rear axles? How are they secured from swaying and knocking into each other?
Re: Short article about the origins of the side post battery. [Re: Highboy] #5388389 03/29/20 04:02 AM
M
mcrn Offline
M
Originally Posted by Highboy
[Linked Image]
That is crazy
2012 Nissan Rogue
Re: Short article about the origins of the side post battery. [Re: mcrn] #5388399 03/29/20 04:44 AM
Skeet6 Offline
https://youtu.be/whd_Kd_xxPk
(Some more vertical Vega stuff...)
Neat!
Mike B
