MolaKule
Staff member
Originally Posted by SoNic67
...For LV fluid I am using Valvoline MaxLive (full synth Mercon LV compatible). I would also use Motorcraft LV ( hydroprocessed base oils), Amsoil (Fuel Effiecient line), Red Line D6. Although for a Fusion those last ones might be overkill.
The Motorcraft Mercon LV has a viscosity index (@100C) of 6.0
Valvoline MaxLive has 5.9
AMSOIL OTL has 5.8
Red Line D6 has 6.3
BTW, Mobil 1 Synthetic has 7.25. IMO that's too high for an LV fluid.
Mobil 1 Synthetic LV ATF HP has 5.7, but is listed only for GM. Probably not a big deal, but... IDK.
I think you meant to say:
The Motorcraft Mercon LV has a viscosity (@100C) of 6.0
AMSOIL OTL has 5.8
Red Line D6 has 6.3
Viscosity and Viscosity Index are two different measures.
AMSOIL OTL has 5.8
Red Line D6 has 6.3
AMSOIL OTL has 5.8
Red Line D6 has 6.3
