Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
30 registered members (Cdn17Sport6MT, blufeb95, bachman, alchargo, Avery4, ctechbob, 1 invisible), 1,369 guests, and 29 spiders.
Topics306,109
Posts5,286,660
Members71,586
ramping up production of something #5387297 03/27/20 07:29 PM
A
andyd Offline OP
A
As the US switched to full out war production after 12/7/41. Liberty ships and tankers were mass produced. sub assemblies were parceled out and the pieces were assembled on coastal ways. Kaiser yd put one together in 4 1/2 days. You need something fast, come up with a modular design and sub out each module. This will get supply a complex piece of equipment faster than several suppliers building the entire thing and competing for material from the same suppliers. Use a proven design and piece it out. C'mon this isn't rocket surgery you guys grin2
Thick oil is better grin2
Re: ramping up production of something [Re: andyd] #5387301 03/27/20 07:32 PM
CT8 Offline
We now have China doing the work.It is cheaper and you can dump the toxins in the river.
2015 F150 2.7
2018 F350 6.2
Re: ramping up production of something [Re: andyd] #5387340 03/27/20 08:04 PM
W
Wolf359 Offline
W
It still takes time. Back when ITT was around, we'd always say it takes time. Remember Hitler took power in 1933. The US was starting to wake up to the fact that things weren't looking so good so many things were started years before the invasion of Poland. Ships and new plane designs were started before the invasion. The B-29 that dropped the bomb in 1945 was started in 1938 and the first one didn't fly til 1942.
And for the record, there's no rocket surgery. But it's not quantum mechanics which Richard Feynman who won the Nobel prize for it said "I think I can safely say that nobody understands quantum mechanics".
Re: ramping up production of something [Re: andyd] #5387365 03/27/20 08:37 PM
spackard Offline
When I was working over at Raytheon I saw some papers from that time.
2 shifts of 12 hrs/day, 7 days/wk.
That wouldn't have included commute time, in a bus or a pre-war car (with that reliability).
Not sure today's workers are into that work-life balance/experience.
Re: ramping up production of something [Re: andyd] #5387380 03/27/20 08:50 PM
dishdude Online Content
Online Content
Patent waivers and multiple manufacturers ordered to cooperate and work together are necessary for this to happen as quickly as necessary. As mentioned, complex pieces of machinery require specialized equipment and design - that won't happen overnight without everyone in the supply chain working together and the newbies filling in where the backlog is.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: ramping up production of something [Re: andyd] #5387383 03/27/20 08:53 PM
A
andyd Offline OP
A
The particular piece of equipment is a ventilator and they've been around for a century. Take a state of the art unit under production. Instead of Acme Pumps building the whole unit soup to nuts and competing with Apex Pumps for parts and mkt share. Get Apex to build only a sub assembly and so on..
Re: ramping up production of something [Re: andyd] #5387387 03/27/20 08:56 PM
Online Content
They're going to build a 2020 ventilator, not a 1950's mechanical piece of junk that could potentially make things worse for a patient.
Re: ramping up production of something [Re: andyd] #5387388 03/27/20 08:58 PM
Cujet Offline
While I've never worked any real production manufacturing, I did work for a small firm designing parts for Ford. It was absolutely fascinating, and things happened faster than expected. Once we settled on a camshaft design, 3 Ford engineers were there the next day to get the specs and measure the parts themselves. (just in case we made a mistake) . They wanted the parts that worked, in the exact configuration that worked, and the design went directly into the Mustang SVO.
Pistons came from Brazil, Roller Followers came from some other local NY production shop, that produced our design, and camshafts came from Florida and other locations. But within weeks we had a viable, emissions compliant setup capable of 200+hp at 14 pounds boost, that then went into mass production.
While this seems on the very low side for today's engines, remember this was a Ford Pinto engine, with 2 valves per cylinder, relatively poor port configuration, and a limited RPM capability. They make 300HP with common mods, so they can perform well.
Re: ramping up production of something [Re: spackard] #5387418 03/27/20 09:24 PM
B
buck91 Offline
B
Sounds like the ER to me crazy
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: ramping up production of something [Re: andyd] #5387422 03/27/20 09:31 PM
Astro14 Offline
All right, gentlemen, we know the subject at hand, and we all want to talk about it. But, fundamentally, this is about COVID-19 response, and I think we've said enough at this point.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
