Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
81 registered members (Alfred_B, Blue_Goose, blufeb95, 830Lee, 53' Stude, 7 invisible), 2,245 guests, and 27 spiders.
Topics306,055
Posts5,286,581
Members71,593
Unknown sensor (?) destroyed during accident - 2011 Fusion #5387131 03/27/20 03:17 PM
M
mrsilv04 Offline OP
M
Please refer to the pictures for more information. This is a 2011 Ford Fusion SE with the 2.5 liter engine.
There was something here before the wreck. I'm not sure what it was. A sensor of some sort if I had to guess. Air temperature maybe? Two wire connector.
Need some assistance as to what it was, so I can replace it. Thanks!
BTW, this is my first attempt at bringing a car back after being totalled. No insurance payout on it, so the title will stay clear.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5387137 03/27/20 03:28 PM
K
KGMtech Offline
K
ambient air temperature sensor.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5387161 03/27/20 04:04 PM
cronk Offline
My guess would be an ambient temp sensor. Right area, and connector looks about right.
Ac wont work right without it in most cases.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5387163 03/27/20 04:12 PM
A
atikovi Offline
A
1) How do know it was totalled if there was no insurance involved?
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5387187 03/27/20 04:58 PM
M
mrsilv04 Offline OP
M
The connector on the car is rectangular in shape, with the corners rounded off. The ambient air temperature sensors that I'm seeing images of online, show a round connector, and then it threads into something else.
I'm guessing whatever it was, was bolted on just above the connector (in the close up picture), and some of it is still underneath the bolt.
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5387190 03/27/20 05:06 PM
G
GSCJR Offline
G
Could it be a test connector or simply a spare for other model vehicles with similar harnesses for ad ons?
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5387199 03/27/20 05:12 PM
J
Jethro_Bob Offline
J
Yellow wire, it's likely an airbag sensor.
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5387240 03/27/20 06:39 PM
1
14Accent Offline
1
It's an impact sensor. You can see what's left of it still held by that 10mm bolt.
Here you go:
Ford front impact sensor
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5387279 03/27/20 07:08 PM
M
michaelluscher Offline
M
Plug FORScan into it, self test the GEM, RCM, and PCM
Whatever it was for, you'll get the code for whatever it isn't doing...
'17 CTS Performance AWD 3.6 11K
'06 Camry SE 3MZ-FE 146K
'06 Taurus SE Vulcan 65K
'01 Villager Estate VG33E 55K
'83 Grand Prix LJ 305 SBC 56K
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: atikovi] #5416796 04/29/20 07:52 PM
M
mrsilv04 Offline OP
M
Well, a month later, and the car is done. I only had time to work on it during the weekends.
The grille, bumper cover, and driver's side front fender were repaired and reused. They are not perfect, but neither is the car. The car is 10 years old, with plenty other dents, dings, and scratches unrelated to the accident.
The hood, in the correct color, came from a junkyard in Rockford. It was the only painted body panel that was replaced.
Investment in repairs/supplies was $1400. Car has a clean title, as there was no insurance payout on the accident. What I learned along the way, to keep a car out of the junkyard, was priceless.
Now... the question. Will I ever do this again?
[Linked Image]
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5416799 04/29/20 07:54 PM
dishdude Offline
Looks like it came out well enough for a 10 year old daily driver. Certainly worth the $1400 and a little time on the weekend. With everything going on, this was the perfect time for a little project! You got lucky finding that hood in the same color.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: mrsilv04] #5417217 04/30/20 11:01 AM
J
JTK Offline
J
Nice!!
I'm kind of surprised at the totaled status. The strip down pics above doesn't make the damage look too bad.
Did you ever figure out what that sensor was?
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: JTK] #5417246 04/30/20 11:37 AM
F
ffhdriver Offline
F
OP what's the answer to your original QUESTION ?
Re: Unknown sensor (?) destroyed during accident - 2011 Fusion [Re: JTK] #5418290 05/01/20 01:38 PM
M
mrsilv04 Offline OP
M
Originally Posted by JTK
Nice!!
The sensor was an airbag sensor. Confirmed by our Ford parts man, bdcardinal. Thanks!
It is my belief that an insurance adjuster would have totaled it. I fixed it for $1400. Some of the parts were used, and some of the parts were repaired and reused. My labor cost was $0. A body shop would have added labor at $80 an hour.
A body shop would have charged way more for parts than what I paid. Assume a 50% markup on parts, and 10 hours labor at $80 per hour. That's $2900. Anything beyond that, and it is totaled. An insurance company wouldn't have put much money or effort into trying to fix a $3000 car.
