Originally Posted by sjd
Originally Posted by MolaKule
What specific technical information are you looking for?
The statement that you "can't do a GL-4/5" or whatever that means.
As I posted above, I have run a GL-4/GL-5 oil in a transmission that recommend GL-4 and am taking heat for it from people with no science to back it up just claims of "that's not what Mazda recommends." If you have that science I'd like to hear why. The thread I just posted above some excellent points as to why I can run a GL-4/GL-5 fluid in my transmission that recommends GL-4.
I am not sure what Shannow had in mind since he didn't post a link regarding his statement.
What specific brand of fluid and viscosity are you running and for what vehicle?
Now Subaru had an "S" version of their transaxle fluid which had a common sump for the transmission and the hypoid differential and it was rated GL-5, which meant it had the proper friction modification for the synchro assembly and enough AW chemistry for the differential.
Most modern MT's and transaxles only need a GL-4 rated fluid since the internal loads and gearing type only require that level of wear protection.
My response to the OP, Bill_W, was to replace his fluid from one of from the list of GL-4 fluids I gave in post #5385343.
For more technical information I have an updated White Paper here:
Manual Transmissions and Lubricants
