- Joined
- Nov 29, 2009
- Messages
- 7,268
I need to add coolant to the boat. I bought some supertech extended life for $7.88 thinking it would be regular green since it was so cheap, but I don't know until I open it.
If your do a D/F with conventional green in the system, and you refill with G-05, is that an issue? With a D/F you are of course not getting all of the coolant out.Originally Posted by Donald
I would convert the vehicles using old green to G-05. No reason not to except the time to flush it out.
+1 Million, G-05 is fantastic for systems designed for conventional green.
