'18 GMC Canyon 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
31 registered members (AZjeff, bachman, Alfred_B, bennyG, blufeb95, 3 invisible), 1,341 guests, and 17 spiders.
Topics303,556
Posts5,237,349
Members71,086
What causes an evaporator core to leak? #5386495 03/26/20 07:26 PM
A
atikovi Offline OP
A
Not like it's in front of the car so it can get punctured by a rock. Made of aluminum and located inside the car so won't rust. Are late model Subarus known for leaking evaporators? Pretty much diagnosed it as the source of the leak in my '16. It was blowing cold last fall but nothing now. Compressor engages but low pressure on the test gauges. Recharged and air is ice cold. Used an electronic leak tester and got nothing along the lines under the hood, but as soon as put it to a dash vent, it goes off.
Re: What causes an evaporator core to leak? [Re: atikovi] #5386503 03/26/20 07:34 PM
Chris142 Offline
If you have the fan on your sniffer will go off if the air is blowing across it. Try blowing into your sniffer to see for your self
Evaps can fail from just bad quality, acids in the system from not vacuuming it or filling it from a can. The most common is debris in the case that stay wet and corrode the evap.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What causes an evaporator core to leak? [Re: atikovi] #5386504 03/26/20 07:37 PM
I
irad Offline
I
Aluminum(Al) can get galvanic corrosion. If Al comes in contact with copper or zinc Al acts as the sacrificial metal. It can also occur when frost on the fins melts and there are salts in the air, like at the beach.
Re: What causes an evaporator core to leak? [Re: Chris142] #5386513 03/26/20 07:47 PM
A
atikovi Offline OP
A
No, it was with the a/c off.
Re: What causes an evaporator core to leak? [Re: atikovi] #5386530 03/26/20 08:01 PM
Z
zzyzzx Offline
Z
You are wondering why something made in China had failed???
Re: What causes an evaporator core to leak? [Re: atikovi] #5386533 03/26/20 08:03 PM
A
atikovi Offline OP
A
How would you know it was made in China?
Re: What causes an evaporator core to leak? [Re: atikovi] #5386536 03/26/20 08:05 PM
dishdude Online Content
Online Content
Usually the passenger side floor vent is the best to use the sniffer on, typically it's closest to the heater box.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: What causes an evaporator core to leak? [Re: dishdude] #5386543 03/26/20 08:08 PM
A
atikovi Offline OP
A
The floor vent doesn't get any air conditioned air.
Re: What causes an evaporator core to leak? [Re: atikovi] #5386580 03/26/20 08:33 PM
N
nwjones18 Offline
N
I stick the sniffer in the drain tube to test for them. I had to replace the one in my wifes 2008 CRV. I don't know why they fail, but everything does eventually..
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: What causes an evaporator core to leak? [Re: atikovi] #5386598 03/26/20 09:04 PM
2
2009Edge Offline
2
Usually its a HOLE crzy
Re: What causes an evaporator core to leak? [Re: atikovi] #5386599 03/26/20 09:04 PM
stevejones Offline
My guess would be metal fatigue after xxx number of contractions/expansions....
Re: What causes an evaporator core to leak? [Re: atikovi] #5386601 03/26/20 09:05 PM
2
2009Edge Offline
2
Re: What causes an evaporator core to leak? [Re: atikovi] #5386676 03/26/20 11:35 PM
1
14Accent Offline
1
Don't be surprised, you aren't alone. I've seen many 2010-2014 Subaru's with Evap core leaks. Why? I couldn't tell you. What I can tell you is that it's relatively easy to replace, does NOT require dash removal, and can be done with hand tools in a driveway in an afternoon. Just pay a shop to evacuate and recharge the system, and you'll be all set.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: What causes an evaporator core to leak? [Re: atikovi] #5386687 03/27/20 12:28 AM
SLO_Town Online Content
Online Content
Many BMW E90s had evaporators that leaked from new. Imagine having this fixed on a nearly new car. It’s an UGLY job! Instead, I get mine recharged every 2 years.
https://www.youtube.com/watch?v=IYVBcn4LB7I&feature=emb_title
Scott
03 BMW E46 330Ci ZSP (Euro Castrol 0W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: What causes an evaporator core to leak? [Re: atikovi] #5386720 03/27/20 03:55 AM
G
Gebo Offline
G
Incorrect coolant, neglected coolant or inferior/weak part.
Often it is due to coolant wearing out over time and becoming acidic which corrodes aluminum.
How often do you change your coolant and what coolant do you use?
If you can get your hands on a pH stick and check the pH of the coolant you could see if the pH is below 7.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
