Broken sway bar bolt
by HoosierJeeper - 03/29/20 04:00 PM
can I use it?
by avi1777 - 03/29/20 03:54 PM
Service Champ OF2222 75% OLM, unknown miles
by bullwinkle - 03/29/20 03:50 PM
Gas Buddy Question
by Wolfshead - 03/29/20 03:30 PM
Caliper piston boot
by painfx - 03/29/20 03:25 PM
Graphene the next detailing protection
by Mamala Bay - 03/29/20 02:17 PM
Anyone here a blacksmith?
by 53' Stude - 03/29/20 02:13 PM
Buying products made outside the USA
by 007 - 03/29/20 01:22 PM
Marine oils on sale at Canadian Tire
by Snagglefoot - 03/29/20 12:42 PM
0W16 instead of 0w20?
by Mter00s - 03/29/20 12:36 PM
XG10575 Walmart.com deal
by 762fermeandyou - 03/29/20 12:29 PM
Virgin ACDelco PF1245 cut and post
by nwjones18 - 03/29/20 11:49 AM
Oups, forgot oil cap...
by M119 - 03/29/20 11:46 AM
Recommendation for tuned BMW N55?
by RIPGermanCastrol - 03/29/20 11:15 AM
Electrician's Help With Circuit Breaker ?
by doitmyself - 03/29/20 11:07 AM
Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
108 registered members (alphadog, 2K2AcuraTL, 53' Stude, 01rangerxl, 007, 762fermeandyou, 12 invisible), 2,146 guests, and 20 spiders.
Topics303,322
Posts5,233,908
Members71,038
Hub over Rotor advantages? #5386494 03/26/20 07:25 PM
Z
zmelli Offline OP
Z
Having the dreaded HOR design, changing the Rotors is a pain. I was wondering why this design was used back in the nineties. The design does appear to secure the Rotor better than the ROH set-up. Any thoughts?
06 Acura TSX 6-Speed/ASM 0W40/js C809j
93 Honda Accord 0W-40Edge/Micro T7316
"Dr House - the concept you have about me won't change who I am, but it will change my concept of you"
Re: Hub over Rotor advantages? [Re: zmelli] #5386506 03/26/20 07:41 PM
Z
zmelli Offline OP
Z
One advantage that I just found is that uneven or over-torq of the lug nuts may not have the same effect on the rotors, less likely to warp.
Re: Hub over Rotor advantages? [Re: zmelli] #5386525 03/26/20 07:57 PM
Silk Offline
Organic pads of the day caused less rotor wear, they often lasted the life of the car. We call them a captive rotor.
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Hub over Rotor advantages? [Re: zmelli] #5386591 03/26/20 08:46 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Interesting design. Opposite of my Mercedes cars, where the rotor bolts to the hub, which has the bearing races and gets set for play.where is the bearing in that type of design? Seems like it would be an intermediate design, maybe offering some manufacturing simplicities versus the old school rotor-hub design like my cars have, but older school then the subsequent approaches where the rotor just attaches with a single screw or slides over the lug bolts?
Re: Hub over Rotor advantages? [Re: zmelli] #5386673 03/26/20 11:28 PM
slacktide_bitog Offline
If I had that car, I'd do the regular hub and rotor conversion ontome
Rotors are wear items; hubs are not
Re: Hub over Rotor advantages? [Re: zmelli] #5386833 03/27/20 08:20 AM
W
WyrTwister Offline
W
First time I have seen that . Do not think I would like it ?
Wyr
God bless
Re: Hub over Rotor advantages? [Re: WyrTwister] #5386854 03/27/20 08:44 AM
T
The_Eric Offline
T
You wouldn't...
Remove hub bearing assembly from vehicle and press wheel studs out to remove rotor, which slips on/off the back of the bearing. Nothing like turning a simple job into a much bigger one.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Hub over Rotor advantages? [Re: zmelli] #5386871 03/27/20 09:02 AM
W
WyrTwister Offline
W
Sounds like that generates labor hours for the mechanic .
On the other hand , I rarely have to change / replace rotors / drums . Since I finally convinced my wife to STOP driving as soon as she hears metal to metal .
I am rather intrigued . We purchased out 2015 Chevy Sonic new . It now has 70,000 + miles on it and I have not had to touch the brakes .
I drove a 2008 Silverado HD work truck 1500 a few years ago . At ~ 100,000 miles , I did the front disc brake pads . ( Rotors were fine . )
Pads could have gone another 20,000 - 30,000 miles . I was really surprised .
Wyr
God bless
Re: Hub over Rotor advantages? [Re: zmelli] #5386875 03/27/20 09:07 AM
R
ragtoplvr Offline
R
Last new rotors I put on got a thick coat of header paint. Then I removed it where the pads rub and on the center feature of the hub. Used very sticky grease on the center feature.
Rod
Re: Hub over Rotor advantages? [Re: ragtoplvr] #5386934 03/27/20 10:30 AM
Yah-Tah-Hey Offline
Rod
When I purchase a new vehicle, I remove the brake rotors and burnish a small amount of anti-seize on the inside of the disc to hub interface. Going on sixteen years and no rust with no problem removing discs.
Re: Hub over Rotor advantages? [Re: zmelli] #5386941 03/27/20 10:46 AM
bdcardinal Online Content
Online Content
Honda Accord right? I had the special tool from MATCO for those rotors so you didn't have to use a slide hammer. Ended up not being worth it because the jerk manager of the shop I worked at then wouldn't charge the proper labor. He said that since it took me less time he couldn't charge more, even though I had an extra $350 in the tool mad
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Hub over Rotor advantages? [Re: zmelli] #5387007 03/27/20 12:17 PM
E
exranger06 Offline
E
I have absolutely no idea why Honda designed them like that. I did the rotor over hub conversion on my '92 Accord so I wouldn't have to deal with that nonsense any more. After I finished the conversion, I thought "Now why the heck didn't Honda do it like this in the first place?" I still don't have an answer to that question.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Hub over Rotor advantages? [Re: zmelli] #5387016 03/27/20 12:40 PM
5
5AcresAndAFool Offline
5
That design makes me very angry, I did alot of brake jobs on honda accords and k2500 chevy trucks back in the day with captive rotors. I damaged a few bearings on the accords despite trying not too. Being in rust country didnt help.
The the last independent shop i worked at got an on the car lathe right before I left, this helped greatly on the accords IF the rotors were not too thin.
The chevy dealer I worked at got an on the car lathe just as the Chevy Colorado's came out as they had captive rotors as well and GM seemed the lathe an essential tool.
Captured rotors are a PITA!
Re: Hub over Rotor advantages? [Re: zmelli] #5387278 03/27/20 07:08 PM
Silk Offline
It wasn't just Honda who did captive rotors, all the Japanese fwd cars had them...it was just how it was done in those days.
Re: Hub over Rotor advantages? [Re: zmelli] #5387376 03/27/20 08:43 PM
H
hpb Offline
H
Yep, that's how they were. Remember on the late '80's and early '90's Ford Laser/Mazda 323 pressing the front hubs apart to repack the wheel bearings every 40,000km - it was part of their service schedule.
MY16 Mitsubishi Outlander 2.2 diesel, 66,000km - Gulf Western Euro Energy 5w30, Mitsubishi filter
2006 Ford Falcon 4.0, 153,000km - Valvoline Engine Armour 15w40, Ryco filter
