Honda PS pump bearing
Madiganistan/Chiraq
Since ive got extra time on my hands these days...instead of just buying a new PS pump for my 2012 Odyssey and swapping it out. I ordered some parts to rebuild it. new orings, seal and a bearing
I haven't taken it off yet but every video I have watched shows the bearing rubber shielded on the outer edge and metal shielded on the inside.
The bearing I ordered off amazon FEBEST BEARING LINK
Has rubber on both sides
the honda part i believe should look like this
[Linked Image from i.avto.pro]
does it matter if it has rubber on both sides?
That looks like a generic 6200 or 6300 series bearing. There are options for the side covers.
If it's inside the case and submerged in fluid you'd just remove the rubber and wash out the factory grease so it will be lubricated by fluid.
