Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
104 registered members (4WD, amblerman, apollo18, 2015_PSD, ArrestMeRedZ, agarb, 11 invisible), 2,298 guests, and 37 spiders.
Topics305,923
Posts5,282,810
Members71,537
2017 Jeep Cherokee 4x4 Low Speed Turn Vibration #5385712 03/25/20 07:06 PM
G
Greggy_D Offline OP
G
Looking at buying a 2017 Jeep Cherokee 4x4 with 36,200 miles. At times, when turning left or right at a slow speed you can feel a vibration throughout the vehicle coming from the drivetrain.
If I go into a parking lot and turn in forward circles with the wheel at its stop (L or R), I always feel the vibration. Put the vehicle in reverse, without moving the wheel from its stop, go in circles and the vibration is gone. Put it back in drive, vibration is back.
Any ideas?
Greggy D.
Re: 2017 Jeep Cherokee 4x4 Low Speed Turn Vibration [Re: Greggy_D] #5385723 03/25/20 07:31 PM
Danno Online Content
Online Content
What is the AWD dial between the front seats set at?
Would 4WD been on, on dry pavement? You could be feeling driveline judder, which would be normal.
If in Auto, in other words 2WD, could be CV joint issues. Its just out of basic warranty so tread carefully
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 2017 Jeep Cherokee 4x4 Low Speed Turn Vibration [Re: Greggy_D] #5385726 03/25/20 07:31 PM
G
Greggy_D Offline OP
G
The dial is in Auto. Dry pavement.
Greggy D.
Re: 2017 Jeep Cherokee 4x4 Low Speed Turn Vibration [Re: Danno] #5386017 03/26/20 09:17 AM
O
OVERKILL Offline
O
I know in my GC there is no 2WD. Auto in mine still has all 4 wheels engaged and there is no 2WD setting. Depends on the transfer case employed, the Pentastar equipped GC's are the same, as is the Durango. Not sure what the case is on the Cherokee, but it may be similar (just throwing that out there).
OP: Sounds like it could be feathering on the outside or inside edges of the tires, is there any visible?
Re: 2017 Jeep Cherokee 4x4 Low Speed Turn Vibration [Re: Greggy_D] #5386094 03/26/20 10:31 AM
J
JTK Offline
J
Are these designed like your run of the mill FWD/4x4, where the transaxle spins the t-case/PTU and rear prop shaft 100% of the time and 4x4 is turned on/off by an electromagnetic coupling at the rear diff input?
In "auto" mode, maybe those tight turns and different wheel speeds is triggering the rear coupling to engage a bit.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 2017 Jeep Cherokee 4x4 Low Speed Turn Vibration [Re: Greggy_D] #5386316 03/26/20 03:17 PM
G
Greggy_D Offline OP
G
4 brand new tires
Greggy D.
