Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
117 registered members (2015_PSD, Al, Alfred_B, 2003f7, 97prizm, 14Accent, 12 invisible), 2,436 guests, and 62 spiders.
Topics305,921
Posts5,282,787
Members71,537
propane outboard anyone? questions... #5385992 03/26/20 08:40 AM
1
1978elcamino Offline OP
1
I just recently got permission from a neighbor that I can use the lake, my son and I want to fish this lake. I have been looking for a small motor for my 10' jon boat but dont want a gas engine due to infrequent use. The least expensive I have seen is a coleman 5hp (dont want less than 5hp) does anyone have experience with propane outboards or know any other 5hp propane under a grand?
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386004 03/26/20 09:00 AM
F
FastLane Offline
F
Mercury has a propane outboard. No idea what it costs. I would buy a gas outboard myself. Only put in the gas your going to use. That’s what I did with a 4hp. I took along a small jerry can just in case on longer trips. No big deal. Dump the gas in your vehicle if you don’t end up using it.
2010 Silverado 4.8 4x4 Mobil 1 5W30 Fram XG10060
2002 Mustang GT 4.6 Mobil 1 5W30 Fram XG2
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Lund SV16
2007 Yamaha Nytro
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386009 03/26/20 09:10 AM
1
1
I thought of that but and still on the fence between an electric trolling motor and the propane outboard. With such infrequent use im trying to get something that requires no maint.
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386021 03/26/20 09:23 AM
DriveHard Offline
no maintenance and a boat is a terrible combination that will only lead to trouble...boats and boat motors are work. This is not where you want to skimp on reliability.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386033 03/26/20 09:37 AM
supton Offline
Buy the son a set of oars? Might make more noise than an outboard though.
How much gas are you thinking of going through? I wonder if "expensive" ethanol free would be best, with a conventional 2 stroke.
Personally I'm hearing an excuse here for why you need to go more often--so as to avoid buying an expensive propane motor.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386077 03/26/20 10:14 AM
dadto2 Offline
I don't think your john boat and small outboard will require any maintenance. In 1980, my dad bought a brand new 2 stroke Evinrude 9.9. It *may* have had a spark plug replaced somewhere along the line. It gets very low hours, as its the second to the ski boat. Every fall, the motor gets put away in the heated basement. Next month we'll take it back to the cottage. I expect it will fire right up on the second or third pull like it always does.
Just realized that 1980 was 40 years ago... crzy
'16 GMC Sierra 1500 Crew Cab 4.3
'15 Volvo S60 T5 AWD
'99 Volvo S70 2.4
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386128 03/26/20 11:15 AM
J
JTK Offline
J
I would think the fuel burn rate with propane would be horrendous for a boat motor.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386131 03/26/20 11:15 AM
Cujet Offline
A viable electric outboard is silly expensive, about $4K for something that can make a real-world 2 HP. Plus the need for a $3K battery that lasts 5 years.
https://www.torqeedo.com/us/en-us/products/outboards/cruise/cruise-2.0-t/M-1234-00.html
https://www.torqeedo.com/us/en-us/products/batteries/power-24-3500-/2106-00.html
I suggest you look into the new ultra-low emission 5HP Honda outboard and run non ethanol gasoline in it. Can be found for under $1200.
Although it might seem like overkill, using VP-C9 from VP fuels, or Sunoco Ultra 95 oct fuel (you can order these in 5 gallon pails) might make a lot of sense. It won't cost you more than a propane setup and the fuel NEVER goes bad. So every year, it will work just fine.
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386152 03/26/20 11:45 AM
F
Fitz98 Offline
F
I don't know anything about propane motors, so I can't comment on that, but when I got my boat that has a 200 hp 2 stroke Merc, I changed all the fuel lines. They had a yellow brittle film on the inside, I think caused by ethanol. Then switched over to non-ethanol fuel and add the recommended dosage of Mercury Quickare fuel treatment every trip. The fuel system stays clean and the boat starts right up, even after months of sitting. I do start it up every 2-3 weeks, but the fuel in the tank might sit for months at a time and is still perfectly clean. I think ethanol free and the fuel additive makes for a very low maintenance outboard solution on the fuel system side of things.
2 stroke outboard is not very stealthy though (at least mine isn't) and not very environmentally friendly with all that unburned oil getting exhausted out into the atmosphere and waterways. I can certainly see that as an argument for propane or electric or perhaps a 4 stroke.
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386286 03/26/20 02:26 PM
B
Blkstanger Offline
B
I had a 10' jon boat back in the day and ran an electric trolling motor on it. It worked great for small lakes. Big lakes not so much but I had another motor for that.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 75,000mi. Castrol Edge EP 5w30 Fram Ultra.
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386345 03/26/20 04:27 PM
Geauxtiger Offline
If this is a smallish lake, then a trolling motor would be ideal. Heck, a 50 lb thrust unit, such as this one would give you some pretty darn good speed and you could easily get around any lake under, say, 20 acres. a $250 trolling motor and a $150 deep cycle battery and you are in business. And stealthy.
'14 Silverado Doublecab Pennz Platinum 5w-30
'06 Polaris Sportsman, Amsoil 4-Stroke Powersports 0w-40
'07 Suzuki KingQuad Amsoil 4-Stroke Powersports 0w-40
Re: propane outboard anyone? questions... [Re: DriveHard] #5386375 03/26/20 05:15 PM
JohnnyJohnson Offline
Yes a boat is a hole in the water you pour money into.
2004 Corolla 140080
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: propane outboard anyone? questions... [Re: Geauxtiger] #5386391 03/26/20 05:22 PM
T
totegoat Offline
T
Good advice^^^^^^^
Re: propane outboard anyone? questions... [Re: 1978elcamino] #5386466 03/26/20 06:34 PM
samven Online Content
Online Content
I did a bunch of research on propane motors for my 12' jon boat. I did not want to worry about gas going bad on a motor that would not see much use. I could not find any good reviews or find anyone that was very happy with them. I did finally by a 46 lb thrust trolling motor and 2 gp 24 batteries. I would have gone with a single bigger battery but I am fishing a 50 ac long lake and did not want to run out of juice unexpectedly at the far end but so far I have only used the 2nd battery once and just because the 1st seemed to be getting a bit low and did not want to damage it. It is not fast, maybe 3-4 mph. You will be limited by hull speed like a sailboat because there is no way to get on plane and will find the you only need to use about 3/4 of max power because the last 1/4 wont move you any faster but will use more battery. I also find that I find more fish when moving slowly in places my buddy used to zoom over. Save the money on the motor and get a portable fish finder.
Re: propane outboard anyone? questions... [Re: JohnnyJohnson] #5386839 03/27/20 08:28 AM
1
1
Yes, this I know. I already have a boat that is old, its 22ft and is a 1985 with a 2003 2t outboard so I understand what dropping money in an endless pit means. This is why Im considering just buying a trolling motor instead. However, this lake is very large for a 10' jon boat, its 140 acres so a gas motor to get us from A to B would be ideal. I will probably just buy a trolling motor and look around for a while for a late model 2 stroke 9.9 outboard. Like samven said, there are not a ton of positive reviews to motivate spending a grand on something else to become a project, I just dont have the time anymore.
