Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
114 registered members (2015_PSD, 77GrandPrix, 14Accent, 5AcresAndAFool, 13 invisible), 1,964 guests, and 60 spiders.
Topics306,109
Posts5,287,681
Members71,602
Page 1 of 3 1 2 3
Ok to change oil and NOT filter? #5386192 03/26/20 12:31 PM
L
Lolvoguy Offline OP
L
Recently the weather's been getting warmer, so I know it's time for my annual change on the Lexus.
After reviewing the maintenance book, it seems as though I've only driven it a paltry 2,000kms/1250 miles in the last year (since March 2019).
For oil I'm running full syn Pennzoil platinum 5w30. No leaks/burning as it only has roughly 55k miles
Since the car does it's fair share of stop and go driving, I'm thinking I should at least refresh the additive package in the oil.
Should I change the filter too? The owners manual says you can get away with doing it every other change...
thoughts? opinions?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386198 03/26/20 12:37 PM
K
ka9mnx Offline
K
Go another year on both.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Ok to change oil and NOT filter? [Re: ka9mnx] #5386201 03/26/20 12:40 PM
B
BMWTurboDzl Offline
B
My opinion as well.
435i
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386202 03/26/20 12:40 PM
T
Triple_Se7en Online Content
Online Content
T
1250 x 3
Go another two years. 3750 miles is low on a basic filter these days.
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386206 03/26/20 12:44 PM
Bryanccfshr Offline
It will be fine to leave the filter on and change the oil if you think it is required based on your service.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386207 03/26/20 12:45 PM
J
JeffKeryk Offline
J
I had a similar question on our trusty Tundra.
About 4,000 in maybe 16 months.
I didn't want to dump 7 quarts of M1 High Mileage 5w30 and the M1 filter...
Ultimately I did a spill and fill with Valvoline HM 5w30 and left the filter for another year.
Necessary? Probably not; dunno. Did I sleep better? Heck yeah.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386216 03/26/20 12:57 PM
A
atikovi Offline
A
OK but at least remove and drain the filter if its a spin-on.
Re: Ok to change oil and NOT filter? [Re: atikovi] #5386222 03/26/20 01:07 PM
B
blufeb95 Online Content
Online Content
B
That's a bad Idea, oil filter gaskets typically get compressed after a year and they aren't meant to be re-used.
Re: Ok to change oil and NOT filter? [Re: atikovi] #5386223 03/26/20 01:07 PM
T
Online Content
T
I have done that and never had a leak.
But - about 15 years ago I did it and the old, used Fram EG gasket stayed on the filter housing base. Had a mess on my driveway after I installed the new oil filter and haven't bought Extra Guards since.
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386225 03/26/20 01:09 PM
R
ragtoplvr Offline
R
Some low end filers may split or tear after soaking on oil for 2 years. At least 40 years ago in a Mobil 1 study they did.still true, I do not know.
Re: Ok to change oil and NOT filter? [Re: blufeb95] #5386227 03/26/20 01:12 PM
A
atikovi Offline
A
Nonsense. They are made of a rubber like material and you can always tighten it a little more. If it's gotten that hard, it needs to be replaced anyway.
Re: Ok to change oil and NOT filter? [Re: blufeb95] #5386233 03/26/20 01:16 PM
CR94 Offline
So what? If it's slightly compressed, you'll compensate by screwing it slightly farther on. I removed and re-used spin-ons many times with no leaks. If concerned, check for leaks after a few drives and re-tighten if needed.
You can drain most of the old oil from the housing on a cartridge filter without even taking the filter out---not that it matters a whole lot.
2011 Toyota Prius now at 110K
Re: Ok to change oil and NOT filter? [Re: atikovi] #5386235 03/26/20 01:20 PM
N
nwjones18 Online Content
Online Content
N
Yeah but its just not worth it.. If I'm going through the mess of removing I'm not going to reinstall an old filter.. I'd let the oil/filter combo go another year. I have a truck that gets similar mileage put on it and I'm changing every 2 years.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386239 03/26/20 01:24 PM
blupupher Offline
Yes, you can.
The real question is should you bother?
I don't know anything about that motor, but if it is not a GDI/TGDI motor and oil does not smell like gas, I would leave it alone for another year.
Or just change both, $20-30 is not that big a price for piece of mind.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/ProGuard
'12 xB: M1 EP 0W-20/CQ Blue
'10 Santa Fe: Synpower 5W-30/D+
'04 F150: Magnatec 10W-30/ST
'02 F150: PP 0W-20/M1
'94 VT1100: Peak 15W-40/Wix
Re: Ok to change oil and NOT filter? [Re: nwjones18] #5386246 03/26/20 01:33 PM
A
atikovi Offline
A
It's also not worth changing the oil and then diluting it with the old oil in the filter when it's so easy to drain it. A good filter has plenty of life left after just 1200 miles so no need to replace it.
Page 1 of 3 1 2 3
