CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
Life2race, rider9195, kingsville911, B34R, ChrisSnowden
71056 Registered Users
115 registered members (AC1DD, 14Accent, 2009Edge, 2010Civic, 53' Stude, aquariuscsm, 13 invisible), 1,823 guests, and 22 spiders.
Topics303,359
Posts5,234,757
Members71,056
Page 1 of 3 1 2 3
Ok to change oil and NOT filter? #5386192 03/26/20 12:31 PM
L
Lolvoguy Online Shocked OP
OP Online Shocked
L
Recently the weather's been getting warmer, so I know it's time for my annual change on the Lexus.
After reviewing the maintenance book, it seems as though I've only driven it a paltry 2,000kms/1250 miles in the last year (since March 2019).
For oil I'm running full syn Pennzoil platinum 5w30. No leaks/burning as it only has roughly 55k miles
Since the car does it's fair share of stop and go driving, I'm thinking I should at least refresh the additive package in the oil.
Should I change the filter too? The owners manual says you can get away with doing it every other change...
thoughts? opinions?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386198 03/26/20 12:37 PM
K
ka9mnx Offline
K
Go another year on both.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Ok to change oil and NOT filter? [Re: ka9mnx] #5386201 03/26/20 12:40 PM
B
BMWTurboDzl Offline
B
My opinion as well.
435i
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386202 03/26/20 12:40 PM
T
Triple_Se7en Offline
T
1250 x 3
Go another two years. 3750 miles is low on a basic filter these days.
Keep Your Pistons Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386206 03/26/20 12:44 PM
Bryanccfshr Offline
It will be fine to leave the filter on and change the oil if you think it is required based on your service.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386207 03/26/20 12:45 PM
J
JeffKeryk Online Content
Online Content
J
I had a similar question on our trusty Tundra.
About 4,000 in maybe 16 months.
I didn't want to dump 7 quarts of M1 High Mileage 5w30 and the M1 filter...
Ultimately I did a spill and fill with Valvoline HM 5w30 and left the filter for another year.
Necessary? Probably not; dunno. Did I sleep better? Heck yeah.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386216 03/26/20 12:57 PM
A
atikovi Online Content
Online Content
A
OK but at least remove and drain the filter if its a spin-on.
Re: Ok to change oil and NOT filter? [Re: atikovi] #5386222 03/26/20 01:07 PM
B
blufeb95 Online Content
Online Content
B
That's a bad Idea, oil filter gaskets typically get compressed after a year and they aren't meant to be re-used.
Re: Ok to change oil and NOT filter? [Re: atikovi] #5386223 03/26/20 01:07 PM
T
T
I have done that and never had a leak.
But - about 15 years ago I did it and the old, used Fram EG gasket stayed on the filter housing base. Had a mess on my driveway after I installed the new oil filter and haven't bought Extra Guards since.
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386225 03/26/20 01:09 PM
R
ragtoplvr Offline
R
Some low end filers may split or tear after soaking on oil for 2 years. At least 40 years ago in a Mobil 1 study they did.still true, I do not know.
Re: Ok to change oil and NOT filter? [Re: blufeb95] #5386227 03/26/20 01:12 PM
A
Online Content
A
Nonsense. They are made of a rubber like material and you can always tighten it a little more. If it's gotten that hard, it needs to be replaced anyway.
Re: Ok to change oil and NOT filter? [Re: blufeb95] #5386233 03/26/20 01:16 PM
CR94 Offline
So what? If it's slightly compressed, you'll compensate by screwing it slightly farther on. I removed and re-used spin-ons many times with no leaks. If concerned, check for leaks after a few drives and re-tighten if needed.
You can drain most of the old oil from the housing on a cartridge filter without even taking the filter out---not that it matters a whole lot.
2011 Toyota Prius now at 109K
Re: Ok to change oil and NOT filter? [Re: atikovi] #5386235 03/26/20 01:20 PM
N
nwjones18 Offline
N
Yeah but its just not worth it.. If I'm going through the mess of removing I'm not going to reinstall an old filter.. I'd let the oil/filter combo go another year. I have a truck that gets similar mileage put on it and I'm changing every 2 years.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Ok to change oil and NOT filter? [Re: Lolvoguy] #5386239 03/26/20 01:24 PM
blupupher Offline
Yes, you can.
The real question is should you bother?
I don't know anything about that motor, but if it is not a GDI/TGDI motor and oil does not smell like gas, I would leave it alone for another year.
Or just change both, $20-30 is not that big a price for piece of mind.
'18 Santa Fe: PP 10W30/OEM
'18 Soul: Synpower 5W30/ProGuard
'12 xB: M1 EP 0W20/CQ Blue
'10 Santa Fe: Synpower 5W30/D+
'04 F150: Magnatec 10W30/ST
'02 F150: Magnatec 5W20/D+
'94 VT1100: Peak 15W40/D+
Re: Ok to change oil and NOT filter? [Re: nwjones18] #5386246 03/26/20 01:33 PM
A
Online Content
A
It's also not worth changing the oil and then diluting it with the old oil in the filter when it's so easy to drain it. A good filter has plenty of life left after just 1200 miles so no need to replace it.
Page 1 of 3 1 2 3
