2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
113 registered members (5AcresAndAFool, 92saturnsl2, Alfred_B, ABomb369, 53' Stude, 16 invisible), 1,732 guests, and 24 spiders.
Topics303,453
Posts5,235,482
Members71,072
14 Forester XT Starter Going Bad #5386174 03/26/20 12:11 PM
gathermewool Offline OP
~78k miles
Started a couple of months ago, getting worse
Symptoms: starter is whirring noise is louder and continues for a second after the engine is started before loudly winding down. According to the all-knowing etherwebs, the starter is going bad.
Confirmation: The dealer confirmed that the clutch is not disengaging when it should, resulting in the excessive noise. They recommend replacement.
Cost: $380 for a Subaru reman. with 12-month warranty. For that price and it being a Subaru reman, I'm going to let them do the job.
-----New OE starter is $359.09
Thoughts? I have the capability to replace a starter, but have never done it. I fear the hardest part will be getting the intercooler off. I had a heckuva time getting the intake ducting between the air box and turbo off while replacing the passenger-side spark plugs, it was so stuck together.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5386178 03/26/20 12:15 PM
P
Pelican Offline
P
I'd let the dealer do it so if later you have any problems they can't say the installation was faulty.
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5386189 03/26/20 12:29 PM
CT8 Offline
Get the starter fixed.
2015 F150 2.7
2018 F350 6.2
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5386205 03/26/20 12:44 PM
T
Trav Offline
T
A lot of VW starters do this, they need the shaft where the drive rides greasing with a high temp grease. After that they are no more trouble.
Not saying that is the case with the Subaru starter but its worth a look. Personally I would buy something like this from a 2018 and toss it in. For 45 bucks and free shipping you cant go wrong.
Quote
Up for sale is the starter removed from a 2018 Subaru Forester it was removed in good working condition
Starter
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5386221 03/26/20 01:05 PM
SubLGT Offline
Originally Posted by gathermewool
.....Symptoms: starter is whirring noise is louder and continues for a second after the engine is started before loudly winding down....
Check out: https://legacygt.com/forums/showthr...mble-grease-reinstall-w-pics-218329.html
Quote
Why does the new starter cost less than the rebuilt starter?
Re: 14 Forester XT Starter Going Bad [Re: Trav] #5386231 03/26/20 01:13 PM
That's the plan. I'll be deciding over the weekend whether to do it myself, is the issue.
My plan is to see if I can get the intercooler and starter off myself easily before doing the job. IF I can easily get it off I'll look for a replacement and do the job myself. IF it's not possible for this shade-tree mechanic I'll have the dealer install the reman. for the above price, which I think is reasonable.
Quote
Starter
That's for the 2.5L. I searched for one for my XT and they're all around $150.
How easy is it to grease the portion you're talking about?
With the current status of things we don't even need a second vehicle for the next few weeks, so this once can sit if I need time to figure things out.
I'm also not rich, but having the new starter come with a warranty sounds appealing. I can imagine that if the reman'd starter lasts a year it'll likely last another 50k+ miles, hopefully MUCH longer.
Re: 14 Forester XT Starter Going Bad [Re: SubLGT] #5386236 03/26/20 01:22 PM
Quote
I saw that install, but totally missed the attached .pdf!!! I kept going through Photobucket and back, because the pics are all messed up in-thread with PB. Thanks!
Sorry about the price confusion - the reman'd price includes installation by the dealer.
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5386276 03/26/20 02:08 PM
T
Trav Offline
T
Quote
Starter
Yes it is easy enough, you do need to pull the armature and drive out though, its no big deal. I see the TYC starter (cheap junk) is the same for both engines. Check the art number for both it may fit.
The 2.5 appears to use a 1.4 kw unit and the 2.0 a 1.2 kw, if its same otherwise the 1.4 kw is a stronger unit.
Even at $150 for a real clean one its a lot better than over 3 bills. No way in Hades would I pay that for such an easy job and a reman at that.
Re: 14 Forester XT Starter Going Bad [Re: Trav] #5386360 03/26/20 04:51 PM
Quote
Starter
I've decided that I'm going to remove it tomorrow and see what I can do. Thanks for the confidence booster, Trav.
I'll be cursing your name if the next picture I post is of the Foz on a flat-bed. Wait, how hard can it be to roll-start a modern auto?
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5386603 03/26/20 09:07 PM
T
Trav Offline
T
I cant remember the last auto trans that used a front and rear pump IIRC it was a Chrysler long before my time.
You could bump start those so I'm told, no rear pump no bump starting.
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5386655 03/26/20 10:43 PM
sxg6 Offline
I agree with relubing the starter, try unbolting from under the car if you can't get to it from up top.
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5387372 03/27/20 08:41 PM
Starter is out!!! I was VERY close to giving up on the bottom bolt, but lay there on my creeper for a bit to think and rest may arms, ended up trying one last time and SNAP! I actually shouted for joy! Lol
Now I need to do more research on how to lube this thing.
Someone on one of the Subaru forums made it seem as if the pinion gear would slide by hand. I applied gentle pressure with a flat-head and it wouldn’t budge.
Any additional help would be appreciated. Worst case: I buy a used starter for less than I would have paid for a reman from the dealer.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5387384 03/27/20 08:54 PM
I think I’ll put a dab of moly on each stud and on the mating surface/flange of the starter for easier removal next time...which hopefully won’t be for a while after I lube and “fix” the starter!
Inter-cooler: super easy to remove. Had it off in just a couple of minutes. This gives you access to the connections to the starter and the top bolt. It also gives you access to the PCV valve.
PCV Valve: has something that resembles pipe door around the top threads. Never saw that before. I’ll have to research whether some sort of thread sealant is needed.
Also, the PCV valve seemed pretty gunked up. I’ve got it soaking in carb cleaner now. I’ll check it tomorrow for proper operation , but will likely just go with a new one.
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5387402 03/27/20 09:14 PM
sxg6 Offline
I wonder if it rotates up and down like this. I'd gently try twisting the gear to see if that'll make it go up.
https://youtu.be/RhdSq4WOaDM?t=501
Re: 14 Forester XT Starter Going Bad [Re: gathermewool] #5387420 03/27/20 09:28 PM
It spins in one direction only, but did not extend. It will not rotate in the opposite direction, though I didn’t try to force it.
