Facebook Marketplace riddled with scam RV ads
by atikovi - 04/01/20 08:14 PM
2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
117 registered members (92saturnsl2, 14Accent, 69GTX, AC1DD, 5AcresAndAFool, ABomb369, 15 invisible), 1,730 guests, and 24 spiders.
Topics303,455
Posts5,235,493
Members71,072
GEOLANDAR M/T G003 - LT295/70R18 #5386136 03/26/20 11:27 AM
P
Perengano Offline OP
P
Lurk a lot and seldom post. Before I pull the trigger on these I'd like a little feedback good and bad. They are going on a 2020 Chevrolet Silverado TB which have 275/65/18 Duratracs. Those tires are ok but I need a good tire for West Texas red mud (if there is such a thing). Mud is the greasiest, stickiest that I've ever had the displeasure of driving through. I figure it's as bad as freezing rain on pavement except you will eventually reach bottom with the mud.
Re: GEOLANDAR M/T G003 - LT295/70R18 [Re: Perengano] #5386175 03/26/20 12:13 PM
Astro14 Offline
I've got no experience with those particular tires, though TireRack has a good write-up on them.
https://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=Geolandar+M%2FT+G003&partnum=97QR8G003
But I am curious why the change in size, going from a 65 aspect ratio to a 70, and adding 20mm to the width is a pretty big change in diameter and width.
You're going up in diameter by about 2 inches and adding an inch in overall width (according to Yoko's data on this tire).
What is the reason for the size change?
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: GEOLANDAR M/T G003 - LT295/70R18 [Re: Astro14] #5386505 03/26/20 07:39 PM
P
P
No real reason other that I prefer larger tires. The tires it has on it look like skateboard rubber in the wheel wells. The truck has a factory 2" lift in front and 2" in the back. Height of the wells are 39" and 41". I'll probably change the rear to 1" so it doesn't look like a Rat Fink mobile.😀
Re: GEOLANDAR M/T G003 - LT295/70R18 [Re: Perengano] #5386594 03/26/20 08:54 PM
Astro14 Offline
Makes sense to me.
Factory size tires on my truck look dinky.
I’m sorry no one has chimed in with some first hand experience.
They look like great tires for what you want. Tire Rack certainly liked them.
32 Packard 15W40
05 MB S600 0W40 M1
Re: GEOLANDAR M/T G003 - LT295/70R18 [Re: Perengano] #5386650 03/26/20 10:28 PM
U
userfriendly Offline
U
I wouldn't go larger than a 285 on the stock 18x8" wheel on 2500 & 3500s A 285/75/18 (11.5x35 inflated) is about the biggest tire that will fit your truck without rubbing or fender cutting.
1500s have 18x8.5" wheels, so 295s are an option.
edit; I have 295/65/20 Toyo CTs on my 2500 GMC. Good mud/snow tire.
www.tiresize.com
Re: GEOLANDAR M/T G003 - LT295/70R18 [Re: Astro14] #5386741 03/27/20 05:33 AM
P
P
I'm just happy someone replied. 🤣
Now all I have to do is convince the wife the truck be severely damaged if I don't switch to a bigger tires ASAP. I heard that was the case (on the interwebs 🤯).
Re: GEOLANDAR M/T G003 - LT295/70R18 [Re: userfriendly] #5386742 03/27/20 05:36 AM
P
P
Think I'll check on the 295s. From what I've read they don't rub. More checking to confirm. Thanks for the link.
