Originally Posted by Gokhan
I was disappointed when I got an old stock of M1 EP 0W-20 from Amazon Prime, which didn't have SN PLUS and the latest Ford approval. I know they haven't changed the formula but still... I went to Walmart and got one that carries the latest approvals. I will not buy oil from Amazon Prime again unless I don't have an option.
Amazon Prime M1 EP 0W-20:
Walmart M1 EP 0W-20:
I'm waking up an old thread.
The four-digit number in the ExxonMobil date stamps is the
revision number. It is sometimes followed by the letters
RN. The revision number identifies the formulation. In this case the revision number is
5888, which is the same for both the SN- and SN-PLUS-labeled bottles. Therefore, the formulation is identical for the two bottles, despite one having labeled as SN and the other having labeled as SN PLUS.
Now, the question is if they will change the formulation with API SP, which will come out on May 1, 2020. It would be great if you could record the revision numbers for the API SN vs. API SP ExxonMobil oils and post them here so that we will be aware of the formulation changes if any.
PS: 11019A09A 5888 translates as Plant 110, 2019, Month A (January), Day 09, Formulation 5888 (formulation revision number).
