2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
Twilight Zone
by 2015_PSD - 04/04/20 03:57 PM
Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Kevin1987, Thetrashman33, YLK, 357sig, Garyv
71097 Registered Users
100 registered members (4WD, 2015_PSD, 55hambone, ammolab, 4.8 Silverado, another Todd, 9 invisible), 2,603 guests, and 18 spiders.
Topics303,591
Posts5,237,927
Members71,097
Page 1 of 4 1 2 3 4
Want E0 gas but not for $25/gal? Get yourself some AvGas #5385618 03/25/20 05:07 PM
P
PantherFan88 Offline OP
P
I was sick of buying the canned ethanol free gas at my work, even with a discount, $17/gal is still ridiculous for any gasoline. There is no regular unleaded e0 near me whatsoever. I bit the bullet and went to my local municipal airport. Very easy in and out, the operator filled up my 5 gallon can from the tanker truck. $5.50/gallon for 100LL, 100 octane, leaded gasoline. Just putting the snowblower away, drained the tank/carb, filled it up with AvGas. Runs great! Even when the engine is stone cold, it fires up notably faster with fewer pulls as compared to E10 87. 100LL has a generally agreed upon ten year shelf life, perfect for the generator which sits for indefinite periods, and I won't need to clean out the carb and replace the fuel lines after the ethanol soup turns them to goop every couple years. Most places will fill any gas container.
A few caveats: I would NOT use it with any vehicle/equipment with any sort of exhaust catalyst - it will clog them, and I wouldn't run it year round as from several videos I watched, there are observable lead deposits after even a tankful or two, this is just for long term storage for me. Maybe change the spark plug once a year instead of every other. shrug
Also, some airports will not sell it to you if you claim you are using it for "non-aviation" purposes per FAA regulation, the airports don't care but the FAA does. If asked, I would urge you to say its for "my ultralight that I'm building" or something to that effect.
I even confirmed with my Stihl corporate technical service manager that this stuff is fine for 2-strokes, lasts forever and they love the lead!
Just thought I'd share my experience!
05 Crown Vic 60k - Mobil Super Syn 5w-30 + FL820s
14 Yaris 12k - Mobil Super Syn 5w-30 + 90915-YZZF2
__________
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385630 03/25/20 05:17 PM
Astro14 Offline
To be clear, 100LL is LEADED.
And it has a LOT more LEAD than leaded auto gasoline used to have.
The “low lead” is compared with 115/145 octane for wartime supercharged aircraft engines.
But it is not low lead at all, when compared with automotive gasoline. It runs about four times the concentration of the leaded you could get at the pump.
https://en.m.wikipedia.org/wiki/Avgas#Grades
And lead is a neurotoxin.
There are better ways to get ethanol free fuel...
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: Astro14] #5385633 03/25/20 05:20 PM
P
P
"$5.50/gallon for 100LL, 100 octane, leaded gasoline."
Yes, as I said I am aware it is leaded.
__________
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385637 03/25/20 05:26 PM
B
blufeb95 Online Content
Online Content
B
If your livelihood involves using gas powered equipment most of the day, I probably would skip the leaded fuel.
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385640 03/25/20 05:27 PM
Astro14 Offline
I think it’s a horrible idea. High lead concentration.
Four times the lead concentration of leaded gasoline.
Which has been banned in every country because it’s a neurotoxin.
It’s not the FAA that cares, it’s the EPA.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385643 03/25/20 05:31 PM
M
mk378 Online Content
Online Content
M
Lead is readily absorbed when you breathe exhaust or get it on your skin. This poison is very slow to leave the body. It's crazy to use leaded gas in a handheld engine like a chainsaw.
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385646 03/25/20 05:35 PM
P
P
Oh yeah I agree with all of you, this would never be something used on a daily basis or on a saw that is spewing exhaust 2 feet in front of me. Like I said, this is exclusively storage gas for the OPE with large gas tanks that sits for extended periods of time and is infrequently used.
__________
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385649 03/25/20 05:37 PM
J
Jimzz Offline
J
Have you checked to see if anyone has opened one near you now?
https://www.pure-gas.org/
And no marinas near you?
yup
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385652 03/25/20 05:41 PM
skyactiv Offline
You can make your gas E0 if you really want to. All you need is a 2 liter bottle and some water. Must use 91 or 93 octane as removing the ethanol reduces the octane number. There are Youtube videos showing how to do it.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385661 03/25/20 05:55 PM
T
tomcat27 Offline
T
how can we get legislation reversed that forces the use of E?
and it's surprising how much the lead contaminates the oil. pull the dipstick on any piston powered aircraft.....
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385667 03/25/20 06:11 PM
A
atikovi Offline
A
Makes no sense. When it's time to put it away, either run it until it's dry or drain the tank and run until the carb is empty. Cheap and easy.
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: atikovi] #5385670 03/25/20 06:15 PM
P
P
Don't want the metal gas tanks to rust as they sit empty in my shed with fluctuating temps.
__________
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: Jimzz] #5385674 03/25/20 06:16 PM
P
P
Yeah. All of them within 60 miles are sellers of the canned fuel.
__________
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: Astro14] #5385677 03/25/20 06:18 PM
P
P
Not 4x that of yesterday's car gas.... 100LL "CAN" have a maximum of 2gm TEL per gallon. However, you will not find 100LL with that level of TEL today. As I mentioned above, much of the 100LL available here in the USA is actually 100VLL, with less than 0.5gm TEL per gallon.
__________
Re: Want E0 gas but not for $25/gal? Get yourself some AvGas [Re: PantherFan88] #5385684 03/25/20 06:31 PM
F
Fattylocks Offline
F
I like the idea of gas that's good for 10 years sitting in my generators tank.
94 Caprice Wagon Daily driver sold
05 Focus Wagon 2.0 Duratech city car sold
05 P71 ex Homeland Security
12 Ford Explorer XLT Base
11 Nissan Titan SV King cab 4x4
Page 1 of 4 1 2 3 4
