Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
Help choose a Nissan
by lealedwin485 - 04/06/20 02:31 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
30 registered members (Black_Thunder, carlprop, BlueOvalFitter, cabriopeugeot, blufeb95, 69GTX, 3 invisible), 1,358 guests, and 21 spiders.
Topics303,698
Posts5,240,211
Members71,116
120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d #5385589 03/25/20 04:39 PM
H
heynow Offline OP
H
2013 BMW X5 35d twin turbo diesel 120kmi
Report is from the factory fill ATF
Transmission is a ZF 6hp28x
BMW says that you never need to change the fluid, though ZF later made a recommendation of 60kmi OCI's.
The results are not pretty.
[Linked Image]
1991 Acura NSX
2010 X5 35d twin turbo diesel
2005 BMW r1200GS
Re: 120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d [Re: heynow] #5385602 03/25/20 04:50 PM
T
tundraotto Offline
T
Ouch!
How does it shift now? - and did you change it, and what to?
Re: 120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d [Re: heynow] #5385614 03/25/20 05:02 PM
R
Ram02 Offline
R
But but the engineers said it’s a lifetime fluid and we should listen to them they designed the vehicle
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: 120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d [Re: heynow] #5385662 03/25/20 05:58 PM
T
tcp71 Offline
T
Ford says the same for their version of that transmission, the 6R80. Lifetime my a$$.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: 120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d [Re: Ram02] #5385664 03/25/20 06:03 PM
T
tcp71 Offline
T
Don’t blame the engineers. Engineers do the best they can within the parameters set by management, accounting, marketing, shareholders, etc. Guaranteed the bean counters figured there would be few enough failures during the warranty period to call it a lifetime fluid and reduce the “total cost of ownership” equation that marketing can hang their hat on. So many of the questionable instructions coming from manufacturers have very little to do with engineering. Yes, I design things for a living.
Re: 120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d [Re: heynow] #5385696 03/25/20 06:43 PM
B
benjy Offline
B
lifetime generally means until the warranty runs out!! then its your $$$$$
Re: 120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d [Re: heynow] #5385770 03/25/20 08:32 PM
CT8 Offline
Not to offend the easy to offend but clean oil is happy oil. I'll bet that is a really nice to drive car!
2015 F150 2.7
2018 F350 6.2
Re: 120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d [Re: heynow] #5385880 03/25/20 11:58 PM
G
Gixxer8989 Offline
G
We have a few bmw. I just ordered atf in to do a couple transmissions. After seeing these results I'm glad I did. Wow.
Re: 120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d [Re: heynow] #5385929 03/26/20 06:50 AM
B
BMWTurboDzl Offline
B
OK, so lets unpack this analysis.
To a layman such as myself I see two things.
No 1: "Abrasive and other contaminant levels were normal". - To me this means that filtration was good and the fluid wasn't bad.
No 2: The comments about torque converter, gear & bearing wear suggest that the unit might not be a perfect fit for the application and no amount of fuid changes are going to prevent that wear. Also the analysis says "higher than normal". Well, how much higher than normal? Are we talking a little bit or a lot? What is their population of ZF6HP's? Is it comprised of trucks (Ford) or light weight sedans (3-series, A4 Audis)?
Still, 120k miles. Change and keep on rolling.
Thoughts?
435i
Re: 120kmi factory fill ATF ZF 6HP28X 2013 BMW X5 35d [Re: heynow] #5385983 03/26/20 08:28 AM
A
Audios Offline
A
Bmw used to say lifetime fluid on the pans, but on the workshop sheet it called for oxygen sensors and atf change at 100k, so they assume 100k is the lifetime of the vehicle. This interval went away in 2008 or so
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
