Originally Posted by Olas
Originally Posted by ka9mnx
Yes, I would use a 0w-8 in OZ if the engine required it. No on the 70 in the north. That's the problem. People think they need a 40 in their 20 application because they live in the Desert.
I think you're falling into a semantic trap. The engine oil required by the engine is determined by climate because climate dictates viscosity.
Also, the Arctic is a desert and nobody up there thinks 40 is better thn 20, do they?
Oh my 475 HP BBC with .0025" rod and mains clear, narrowed chamfered bearings, forged pistons and chrome rings - viscosity isn't dictated by climate. If you are starting cold you MUST heat the oil and block.
