M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
Help choose a Nissan
by lealedwin485 - 04/06/20 02:31 PM
Ceramic wax
by rrretiree7 - 04/06/20 02:09 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
29 registered members (E365, BlueOvalFitter, dishdude, Ded Mazai, carlprop, ArrestMeRedZ, 3 invisible), 1,349 guests, and 19 spiders.
Topics303,697
Posts5,240,207
Members71,116
Page 1 of 3 1 2 3
Cicking Noise While Turning Right Only #5384912 03/24/20 07:53 PM
gathermewool Offline OP
Vehicle: 14 FXT with ~ 78k miles
Duration: began soon after I replaced brakes and rotors at all four corners around six months ago - figured I'd mention the brakes, just in case.
Occurance: > 180* turning to the right while accelerating, but it doesn't always occur under the same circumstances. I've turned the wheel hard-over and accelerated and heard NO clicking, for instance. I NEVER hear any clicking on the highway or at anything other than low speeds. The clicking has NOT gotten worse in the past six months.
Note: the boots on all of the CV shafts look great, no tears.
It sounds like a typical CV shaft going bad, but I'm not willing to spend that kind of cash if it's not 100%. Thoughts?
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5384933 03/24/20 08:17 PM
Dave9 Offline
Turn the wheel right, vehicle lifted off that corner on the control arm, and rotate the wheel by hand wiggling it back and forth rapidly to see if there's play in the CV joint. Compare to the left side if in doubt.
If it didn't happen immediately after doing the brakes, I wouldn't suspect them except to make sure things like the bolts haven't come loose. Some applications even recommend threadlock to reduce the chance of that happening.
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5385051 03/25/20 03:19 AM
Char Baby Offline
Check the right side front brake dust shield.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5385057 03/25/20 04:51 AM
F
FT92 Offline
F
had that happen several years ago , turning right sounded like it was coming from the right side but mechanic said left side..most of the weight is transferred to the left side making the noise...he must have been right because after changing the left drive axle noise was gone...just what happened to me
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5385070 03/25/20 05:42 AM
T
Triple_Se7en Offline
T
Similar noise 15 years ago. That was the last time I had a hubcap car and found a small rock bouncing around inside it.
Keep Your Pistons, Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / AC Delco PF 1127
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5385091 03/25/20 06:28 AM
Char Baby Offline
I have experienced so many different types of noises/sounds coming from the bent or moved out of place, backing plates/dust shields alone that, it would make one think that the noise was something entirely different.
I've had backing plates/dust shields make... squeal, grind, thump, click, etc.
All causing me to think the noise was, worn brakes, wheel bearings, strut or stab bar link, halfshaft, respectively.
Or even the sound of a stone kicking around under a wheel cover.
Not saying that the noise isn't something serious or even coming from the opposite side of the vehicle but, check the easiest stuff first.
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5385179 03/25/20 08:12 AM
A
ARCOgraphite Offline
A
Just did mine a couple months ago. Reverse the car with some juice with the steering wheel turned to lock - both ways.
There is a Severe angle on the axle and a lot of orbiting on the joints due to the vehicle lift, and it's likely undderated bits. This all together equals worn out early..
Wife said OURS started acting up and being audible after I did the brakes too. No brakes issues. I pulled the wheels twice to check and even did a disassembly, in front of the suspicious Wife, to assure her the brakes are good to go .... er ... Stop.
Only thing to check is ensure the axle(s) are fully seated in the differential housing. They just pop in, no retainer other tan a spring clip on the axle INSIDE the diff. They can pop out maybe 3/16" and you barely notice.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Cicking Noise While Turning Right Only [Re: ARCOgraphite] #5385207 03/25/20 08:43 AM
R
Randy_R Offline
R
Couple years ago I had a click that turned out to be a front drum brake that didn't self adjust. It was hard to tell where it was coming from, front or back.
2018 Mazda CX-5 6600 miles Zepro advanced moly 0W-20 Mazda filter
08 Saturn VUE AWD 3.5 V6 65,000 miles Schaeffer 9000 5W30 Wix 51522XP
65 Pontiac Tempest 355 Chevy Schaeffer Racing 10W30 K&N
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5385237 03/25/20 09:13 AM
Char Baby Offline
Front drum? Must be on your 65 Tempest. Very cool(My Cousin Vinny).
Re: Cicking Noise While Turning Right Only [Re: Char Baby] #5385288 03/25/20 10:23 AM
R
Randy_R Offline
R
That was a 63, I think, with a transaxle. I got motivated to convert to disc. Got the kit, just gotta install. Marisa is a pretty girl. Maybe I’ll watch it again.
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5385312 03/25/20 10:48 AM
Duffyjr Offline
Just throwing this out there. 99 LeSaber only clicked when turning right most of the time, sounded like it was coming from front left wheel, took it to mech and it turned out the starter drive gear came loose or broke so every time I turned right momentum would throw it into the fly wheel.
89 GMC Sierra Advanced 5w30/51036 Wix
08 Lucerne CX Advanced 5w30/1040 Gold
18 Toro Super Recycler T5 10w30
Re: Cicking Noise While Turning Right Only [Re: Duffyjr] #5385324 03/25/20 11:00 AM
Originally Posted by Duffyjr
Just throwing this out there. 99 LeSaber only clicked when turning right most of the time, took it to mech and it turned out the starter drive gear came loose or broke so every time I turned right momentum would throw it into the fly wheel.
Can’t respond to all now, but this post caught my eye. Our starter just started making noises within this timeframe. The whirring is louder while starting, but it always starts at normal speed. I’ll have to pay attention going forward to whether there’s any overrun.
I’ve actually got two windows of Subaruonlineparts open,one with an axle for $332 and a starter for $380. Yuck...
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5385326 03/25/20 11:01 AM
Duffyjr Offline
Mime sounded normal when starting, I would of never guessed the starter.
Re: Cicking Noise While Turning Right Only [Re: Duffyjr] #5385332 03/25/20 11:05 AM
Was your mechanic able to tighten the starter or was anything damaged?
Re: Cicking Noise While Turning Right Only [Re: gathermewool] #5385349 03/25/20 11:24 AM
Duffyjr Offline
He replaced the starter and said the fly wheel looked ok, it was only doing for a couple days, I always have two vehicles so when something goes wrong with one I drive the other until it's fixed.
Page 1 of 3 1 2 3
