Prolong
by IMSA_Racing_Fan - 04/04/20 01:34 AM
With most folks cooped up at home
by double vanos - 04/04/20 12:58 AM
'18 GMC Canyon Denali 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
36 registered members (Cdn17Sport6MT, Blkstanger, carlprop, blufeb95, AndyB, 3 invisible), 1,119 guests, and 16 spiders.
Topics303,558
Posts5,237,355
Members71,086
Remove Transmission Fluid Stains From Driveway #5384525 03/24/20 12:06 PM
F
Fitz98 Offline OP
F
After dealing with a few transmission leaks and some transmission service, I have a couple basketball size stains in my concrete driveway that I cannot get rid of. I have used a couple different degreasers with coarse scrubbing brush with no effect.
Anyone have any ideas of how to treat these stains without ruining the concrete?
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384526 03/24/20 12:10 PM
J
jayjr1105 Offline
J
Have you tried Brake Parts cleaner or Carb cleaner?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384532 03/24/20 12:17 PM
O
oilpsi2high Offline
O
Dish soap and a pressure washer.
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384540 03/24/20 12:32 PM
4WD Offline
Sometimes you start with “like dissolves like” … Go with oil based like WD40 to break it down … Cat litter to absorb that mess … Lastly Dawn or Greased Lightning etc …
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384544 03/24/20 12:33 PM
Donald Offline
Its hard to damage concrete. So you can be more aggressive than on blacktop. But point blank with the pressure washer jet nozzle may damage the concrete.
I would use Dawn diluted maybe 4 to 1 and let it sit there for a day or more. Maybe cover with plastic so it does not evaporate.
2015 Ford F-250 w/Powerstroke
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384562 03/24/20 12:49 PM
B
buck91 Offline
B
Simple Green will work sometimes but not always. Usually a good winter with plenty of snow will help significantly.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Remove Transmission Fluid Stains From Driveway [Re: buck91] #5384578 03/24/20 01:08 PM
Donald Offline
OP lives in Florida.
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384580 03/24/20 01:14 PM
O
OLEJOE Offline
O
Put some fireplace ashes or hardwood ashes from the grill on it and let it sit. The ashes are so dry and are used to make lye which is a cleaning agent. Let them sit a while then sweep them off and spread them back on the spots. I used this to get 3 gallons of used diesel engine oil off of my shop floor. It works.
Jack of All Trades. Master of some.
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384590 03/24/20 01:25 PM
doitmyself Offline
For some reason, transmission fluid seems to stain concrete unlike anything else I've encountered. I have tried anything and everything to remove the stains with no success.
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384591 03/24/20 01:25 PM
K
Kira Offline
K
Try this. ...doin' this for years.
Get a 4 (or 8) ounce adjustable nozzled spray bottle from the Bed & Bath store near you -one that tightens to pin point.
Fill it with full strength Purple Power
Boil water and be ready to boil more
If applicable, soak the downhill side of the stain or the entire surrounding clean concrete with water so dirty rinse water doesn't stain it.
Pour the boiling water onto the spot slowly and directly. The idea is to impart heat to the concrete at the stain not send boiling water down the clean spots of your driveway. Be precise.
Shoot the heated stain with Purple Power and let it sit 2-3 minutes
Rinse with more hot water. You'll be rinsing and reheating the concrete hopefully deeper and to a higher temperature
You'll see the oily stuff slough off. You'll be glad you protected the clean concrete with the soak
Repeat shoot Purple Power on it. With hotter concrete you can let it sit a minute longer
How it dissolves your stains depends
Multiple rounds are often necessary but this is easy to do. I'll do 5-6 passes and go back to it the next day
This is something you can do on a rainy day
Try this and I guarantee you'll dig up this thread to thank me
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384600 03/24/20 01:32 PM
G
gman2304 Offline
G
Kitty litter, grind it in with your feet....think Chubby Checker, make sure the neighbors aren’t watching, sweep it up with a broom and dust pan. Some chemicals will clean so well you’ll just replace an oil stain with a light spot on the driveway.
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384671 03/24/20 02:54 PM
Danno Offline
Try powdered laundry soap and grind it into the stain with your shoe. Let it sit overnight. Sweep it up.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384693 03/24/20 03:27 PM
E
E365 Offline
E
Blast it with aerosol brake cleaner.
Whatever's on sale...
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384756 03/24/20 04:40 PM
T
Triple_Se7en Offline
T
If the OP is like me, the oil / trans fluid is already gone, but the stain isn't. There's no oil or trans fluid still sitting on top of the discolored stain. All that remains is the discolored stain itself.
That's what he and I want to remove. Mine is former drips from the lousy thick copper oil drain plug washer the dealer used, when I received my free oil change.
Keep Your Pistons, Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Remove Transmission Fluid Stains From Driveway [Re: Fitz98] #5384758 03/24/20 04:41 PM
9
97prizm Offline
9
Pour n restore. Hands down the best stuff
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
