2018 Ford Edge Oil Question
by Passport1 - 03/29/20 04:52 PM
Help school an engineer
by DriveHard - 03/29/20 04:47 PM
Broken sway bar bolt
by HoosierJeeper - 03/29/20 04:00 PM
can I use it?
by avi1777 - 03/29/20 03:54 PM
Service Champ OF2222 75% OLM, unknown miles
by bullwinkle - 03/29/20 03:50 PM
Gas Buddy Question
by Wolfshead - 03/29/20 03:30 PM
Caliper piston boot
by painfx - 03/29/20 03:25 PM
Graphene the next detailing protection
by Mamala Bay - 03/29/20 02:17 PM
Anyone here a blacksmith?
by 53' Stude - 03/29/20 02:13 PM
Buying products made outside the USA
by 007 - 03/29/20 01:22 PM
Marine oils on sale at Canadian Tire
by Snagglefoot - 03/29/20 12:42 PM
0W16 instead of 0w20?
by Mter00s - 03/29/20 12:36 PM
XG10575 Walmart.com deal
by 762fermeandyou - 03/29/20 12:29 PM
Virgin ACDelco PF1245 cut and post
by nwjones18 - 03/29/20 11:49 AM
Oups, forgot oil cap...
by M119 - 03/29/20 11:46 AM
Recommendation for tuned BMW N55?
by RIPGermanCastrol - 03/29/20 11:15 AM
Electrician's Help With Circuit Breaker ?
by doitmyself - 03/29/20 11:07 AM
Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
106 registered members (2K2AcuraTL, andyd, alphadog, 53' Stude, 007, 01rangerxl, 11 invisible), 2,044 guests, and 17 spiders.
Topics303,324
Posts5,233,923
Members71,038
Page 1 of 4 1 2 3 4
Using 0w16 to 'thin down' oil viscosity #5384353 03/24/20 08:32 AM
P
pbm Online Content OP
OP Online Content
P
I have a fair amount of 5w30 and 10w30 full synthetics from sales and 'clearances'.
All but 2 of my family's vehicles use 20 weight oils. What are the opinions of mixing 0w16 and say 10w30
or 5w30 (in summer of course) to get closer to 20 weight? I know some will say "just buy the proper grade oil" but
my first sentence explains why I ask this...
'Journalism is Dead'
Re: Using 0w16 to 'thin down' oil viscosity [Re: pbm] #5384363 03/24/20 08:44 AM
W
WyrTwister Offline
W
I would just use it as is , in the summer . Maybe , year around ?
Wyr
God bless
Re: Using 0w16 to 'thin down' oil viscosity [Re: pbm] #5384369 03/24/20 08:49 AM
A
ARCOgraphite Offline
A
Get a jug of 0w20 or 5W20 and sub in 1 quart per OC. you should be fine.
Problem is many 20 are getting to near 30 grade with D1G2.
Japanese 0W20 are usually real thin, genuine subaru was in the 7's
In the old days we had whale brain oil ATF to add.
That stuff was a super lube.
Poor whales, smarter than us sapiens and ravaged by moronic dopes.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Using 0w16 to 'thin down' oil viscosity [Re: pbm] #5384374 03/24/20 08:56 AM
T
Triple_Se7en Offline
T
I have passed up a thousand oil sales where great money savings exist, but the product is not a fit for my vehicles.
I will blend GDI / TGDI oil viscosites tgether. But I won't blend a SN with a SN Plus - not a Dexos with a non-Dexos. Not a Dexos 1 with a Dexos 2......etc.
In my opinion, doing this weakens the necessary means of what you want the product to accomplish. I blend more than most-all here. But I have my limits on what I use to concoct my own formulas.
Keep Your Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI
20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
04' Chevy Colorado Napa Syn 0w20 and K&N
Re: Using 0w16 to 'thin down' oil viscosity [Re: pbm] #5384376 03/24/20 08:58 AM
K
krismoriah72 Offline
K
"All but 2 of my family's vehicles use 20 weight oils"
that is CAFE talk.
Your owners manual most likely states other alternatives.
Re: Using 0w16 to 'thin down' oil viscosity [Re: krismoriah72] #5384383 03/24/20 09:11 AM
R
racin4ds Offline
R
that is CAFE talk.
Exactly, use the 30WT oils and don't look back, you'll do more harm trying to mix than just running it! Likely your engines will like it better!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: Using 0w16 to 'thin down' oil viscosity [Re: pbm] #5384386 03/24/20 09:13 AM
P
painfx Offline
P
Going up a grade shouldnt hurt.
Re: Using 0w16 to 'thin down' oil viscosity [Re: pbm] #5384396 03/24/20 09:22 AM
SubieRubyRoo Offline
I wouldn't even bother mixing. I know lots of people here that go off the "it didn't cause any visible harm today, so it must be just fine" people like mixing brands and viscosities and base oils, but... no. Nothing will happen from running 5W30 and 10W30 in those engines. As someone stated, just run them in summer so the cold viscosity doesn't matter... the operating viscosity is going to be determined by the temp of the engine & oil, and at 200* there is no meaningful difference between an Xw20 and Xw30. Use as-is!
De omnibus dubitandum.
Re: Using 0w16 to 'thin down' oil viscosity [Re: krismoriah72] #5384397 03/24/20 09:22 AM
A
A
that is CAFE talk.
Not anymore - most don't or "shall not" They have to "require" the viscosity on the 710 and in the OM that was installed and submitted for FE. testing.
Most here should be able to tell if moving up a grade hurts or helps. I would only worry in below zero operation going up a grade ( not a hill!) .
Many japanese engine designs have only a 1/2 thousandth of an inch running main bearing clearance
Re: Using 0w16 to 'thin down' oil viscosity [Re: pbm] #5384410 03/24/20 09:43 AM
T
tig1 Offline
T
I wouldn't mix brands of oil, but if you are mixing within brand I wouldn't have a problem.
2007 Ford Fusion 255,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Using 0w16 to 'thin down' oil viscosity [Re: pbm] #5384415 03/24/20 09:48 AM
J
Jackson_Slugger Offline
J
Just buy an old beater or a fun car and use it in that... smile
Re: Using 0w16 to 'thin down' oil viscosity [Re: tig1] #5384416 03/24/20 09:49 AM
T
T
Oil producers may have the same label....ie.... Mobil-1, but the base oils may come from different parts of our earth - are bottled to be different and so does the additives..... ie.... different molys for example. So sticking with a brand name still spells-out ingredients that are different.
Re: Using 0w16 to 'thin down' oil viscosity [Re: pbm] #5384423 03/24/20 09:53 AM
Snagglefoot Offline
Taking some of the advice already listed, look up the specs of each oil and understand what the kinematic viscosity is of your oil and of the 0w16 at 100 C. If you still want to bring it down go ahead and mix it. I wouldn’t go crazy trying to get it all the way down to the 0w20 range.
Disclosure: I run 5w30 where 5w20 is spec’d in my Fords.
If you want the job done right......do it yourself.
Re: Using 0w16 to 'thin down' oil viscosity [Re: Triple_Se7en] #5384430 03/24/20 09:58 AM
T
tig1 Offline
T
Obviously, but even M1 says that mixing within their brand is not detrimental to their oil, (but best to stay within the wt range) but much better than mixing between brands.
M1 5-20HM
M1 0-20EP
M1 10-30 in all OPE
MC filters
Re: Using 0w16 to 'thin down' oil viscosity [Re: ARCOgraphite] #5384442 03/24/20 10:06 AM
J
Jimmy_Russells Offline
J
Well that was random LOL
Page 1 of 4 1 2 3 4
