CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
Life2race, rider9195, kingsville911, B34R, ChrisSnowden
71056 Registered Users
115 registered members (53' Stude, AC1DD, 14Accent, 2015_PSD, 2009Edge, 2010Civic, 14 invisible), 1,805 guests, and 22 spiders.
Topics303,359
Posts5,234,757
Members71,056
Make your own test leads #5384181 03/23/20 11:10 PM
clinebarger Offline OP
Been slow at the shop.....It's that way at most auto repair garages around here, But I try to make the most of it by cleaning up, maintaining equipment, & fixing/buying/making tools.
I've needed new leads for my Multimeters/Scope/PowerProbe for awhile now.....About destroyed every Alligator Clip adapter I own. Prefer Fluke 4mm Banana test leads but they're pretty high $.
Been getting by with some cheap PVC/Vinyl jacketed leads.....I HATE them with a passion. They get hard & retain the coiled shape they're stored in, On top of them always being too short for the task smirk2
Did a Google search & wasn't impressed with the selection, But did run across this Youtube video & bought the same stuff he used. Spent around $50 after applying my Amazon store card rewards.....Around $70 full price.
Stackable Bananas
Alligators
90 Degree Bananas
14 ga Silicone Jacketed Wire
2001 Chevy Camaro L92/4L80E
Re: Make your own test leads [Re: clinebarger] #5384191 03/23/20 11:23 PM
I recommend using the "Good Stuff" for solder, 60tin/40lead rosin core! Wear gloves & don't chew on it LOL
Love the Silicone Jacketed wire & Stackable Bananas! Made 2 sets of Multimeter Leads with 90° ends & 2 leads with Stackables on both ends as Jumpers/Extensions. Came out to 6' per lead. Gonna order more wire to make some more!!!
[Linked Image from i.imgur.com]
Re: Make your own test leads [Re: clinebarger] #5384192 03/23/20 11:23 PM
Re: Make your own test leads [Re: clinebarger] #5384220 03/24/20 12:25 AM
chemman Offline
Good looking leads! You did a very nice job of fabricating them. Now I guess I should make a couple of sets for use in electronic repairs and for auto repairs!
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: Make your own test leads [Re: clinebarger] #5384232 03/24/20 01:28 AM
U
user52165 Offline
U
I would opt for a respected name like Pomona, Fluke, Probemaster, etc
https://smile.amazon.com/Probe-Master-Softie-Standard-Banana/dp/B0000WUK3K/ref=sr_1_4
The Pomona "grabber" types are essential with today"s electronics. Much better than alligators in tight quarters.
I recently replaced a Honda blend door actuator. The mini grabber were the only thing that would work to test that.
https://smile.amazon.com/Pomona-6343-Basic-Electronic-Test/dp/B000JFL8PC/ref=sr_1_2
https://smile.amazon.com/dp/B005T62WII/ref=psdc_5011675011_t1_B000JFL8PC
Re: Make your own test leads [Re: clinebarger] #5384240 03/24/20 02:26 AM
I like Fluke leads a lot, But in my business....They get damaged eventually. I have T-pins & Needle/pin probes with 4mm banana jacks for tight backprobing.
The big alligators are handy on battery posts & larger bolts for a ground source. I dislike those screw-on mini alligators & prefer the Thexton 490's.....Even solder some wire to them if needed.
Good idea.....I'll solder a length of the silicone jacketed lead to one of the Thexton 490's & put a banana jack on the other end. I'll update after buying some more wire!
We all do things differently, I deal with direct current.......What's the worst that could happen? Grabber type/pierce probes are obviously not essential as I don't use or need them
Re: Make your own test leads [Re: clinebarger] #5384245 03/24/20 03:21 AM
T
tcp71 Offline
T
Don’t worry about chewing the solder, but don’t breath the fumes while soldering. That’s where the lead issue comes into play. Fumes extraction or airflow is important with that much lead.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Make your own test leads [Re: clinebarger] #5384387 03/24/20 09:14 AM
T
Trav Offline
T
Nice job on the cables. Are those long ratcheting box wrenches Mountain RM6?
Re: Make your own test leads [Re: clinebarger] #5384457 03/24/20 10:21 AM
A
andyd Offline
A
Great looking stuff. Back when I was doing shipping+ receiving for a small phone /data outfit. Patch cables with all sorts of specs were hand made and big buxl. I doubt if any of the stuff is US made these days. grin2
Thick oil is better grin2
Re: Make your own test leads [Re: Trav] #5384978 03/24/20 09:10 PM
There the Platinum/ATD branded ones......Same as the Mountain RM6. The 19mm came apart first time I used it because the circlip wasn't seated during assembly. I fixed that & they have been great since. Soak the heads in some ATF & torque on them a few times to free up the back-drag.
Re: Make your own test leads [Re: clinebarger] #5385085 03/25/20 06:15 AM
T
Trav Offline
T
Thanks, I need a set of those badly. I did get the 3/8 drive etorx flex sockets from Snap on you mentioned, they make life easier and what I like most is they don't get sloppy.
Re: Make your own test leads [Re: clinebarger] #5387522 03/28/20 01:41 AM
