When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
Oil change
by IvanPletex - 04/01/20 12:52 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
117 registered members (2009Edge, 53' Stude, AC1DD, 2015_PSD, Astro14, 15 invisible), 1,926 guests, and 26 spiders.
Topics303,444
Posts5,235,397
Members71,072
Ball joint getting the best of me. #5384146 03/23/20 10:17 PM
B
bowlofturtle Offline OP
B
This is on my 2005 Infiniti G35x with 150k, which has been in the rust belt its whole life.
So I was doing my driver's side control arm. Typical inner bushing went bad, I got a new arm.  Turns out sway bar end link was bad as well and my ball joint had some play. Not completely bad, the boot was still there but a little too easy to push around. The wheel had no play when I checked.
With the arm removed, i figure it was cake. Pop the snap ring off from the bottom, took a couple smacks with a 3lb hammer and nothing. I rented the ball joint press. Loaded everything up and it didn't budge. Actually the threaded rod broke off a couple of threads before ball joint pop out. It's pretty dang on in there.
I've done ball joints before, the ones all had the ball joint drop out from the bottom. So a hammer made it easy. the G35 has the ball joint coming up. A lot harder to get leverage when on floor jacks.
Without the snap ring, what is holding the ball joint in? RUST fusion again? I made sure the ball joint had room to clear the cup. And I tighten the press using an impact and then a 3ft breaker bar. I was worried, I know its an OEM unit, could it be tack welded on?
Took a peek at youtube, couldn't find an AWD video but plenty of RWD and very similar setup but I have an axle slightly in the way. They pressed them out without any issues. Since the original ball joint wasn't completely bad, I put everything back together and I might try again on the weekend or ignore until completely bad.
My toys
-05 Infiniti G35x 140k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 20k
-98 Nissan Maxima 160k
-09 Toyota Camry V6 96k
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384168 03/23/20 10:51 PM
P10crew Offline
Heat it up
Re: Ball joint getting the best of me. [Re: P10crew] #5384174 03/23/20 10:57 PM
B
B
Originally Posted by P10crew
Heat it up
Not part of my tool box. I soaked the [censored] out of the ball joint.
The yellow can from homedepot worth anything in terms of heat? I know its not longer real MAPP gas.
My toys
Maintaining
-16 Jetta 1.4T 20k
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384177 03/23/20 11:06 PM
stevejones Offline
For sure get the fake MAPP gas & give it a try - not all the time do you need to get things cherry red...
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384186 03/23/20 11:15 PM
Scuder Offline
Get one of those trigger fired Bernzomatic torches with a bottle of Mapp gas. It's not too expensive. You'll wonder how you ever lived without it. It'll get warm enough to loosen the ball joint. If the control arm is aluminum, you don't want to get it all that hot anyway.
https://www.homedepot.com/p/Bernzomatic-TS4000KC-Trigger-Start-Torch-Kit-TS4000KC/203368730
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384189 03/23/20 11:22 PM
B
Black_Thunder Offline
B
last ball joint i had issues with was on a nissan versa.
eventually i was able to grind the outer ridge off and take the ball part out of the socket, then i punched out the bottom cap so I could get a saw zall blade through the center and i cut into it almost all the way through and that was enough to make it give so i could punch it out the rest of the way.
I'd buy Callahan autoparts if I could.
Re: Ball joint getting the best of me. [Re: Black_Thunder] #5384209 03/23/20 11:55 PM
B
B
I'll consider picking one up. Im a simple DIY guy, if things get annoying i just take it to the shop.
I get the hammering now working but i figure the press should be golden. Ive done 3 others, 2 hammers and 1 press. All non nissans LOL
See if the ball joint was complete junk, i wouldn't mind going crazy on it. But it still kinda good. Boot not broken, its not sloppy like a limp noodle. But just has a little more play then i would like.
My toys
Maintaining
-16 Jetta 1.4T 20k
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384218 03/24/20 12:19 AM
B
B
ah i see, in that case i would have used a grease needle and filled the boot up with grease before reinstalling to help with the little bit of play.
the nissan i worked on had excessive play and the car was shaking badly especially when the brake was applied it was like a death wobble and it was scrubbing off the tire.
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384219 03/24/20 12:20 AM
F
Fitz98 Offline
F
If rust is the issue, Maxdustington on this forum once gave me a tip to remove a rusted EGR connection.
I had tried PB Blaster soaking, hammering, big wrenches, nothing worked.
I put ATF on the rusted connection, a few taps with a hammer and it broke loose in short time with little effort.
His tip was "Use acetone + ATF. I had a stuck clutch bleeder that PB could not break lose. I applied that mixture and it came off with minimal effort. That sold me on it for stuff that PB can't loosen or stuff you will only get one shot at, like a brake bleeder."
I just used straight ATF and worked great for me.
I also use Mapp gas torch when heat won't damage the part or surrounding areas or nothing flammable near by.
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384255 03/24/20 05:02 AM
O
Olas Offline
O
There are three types of ball joint tool that i use on a regular basis - they make it super-easy to remove ones even that are seized in place and don't want to budge.
Fork style seperator
Pusher style seperaotr
Spreader style ball joint seperator
Cable ties should hold it
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384287 03/24/20 06:50 AM
O
Olas Offline
O
*Edit to add this video - its not a 'ball joint' as we commonly know them but a rod-end is still a ball-joint and can give you an idea of how they work..
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384297 03/24/20 07:14 AM
Chris142 Online Content
Online Content
I have never seen a clip that held a ball joint in like you describe. They all press in. I think you remove the arm with the ball joint in it then have it pressed out. Can you post a pic?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384340 03/24/20 08:11 AM
T
tiger862 Offline
T
Are you sure the clip needs to be removed? Most with the clip I have done the clip is used as a stop as you press in until you hit the clip then you know it is pressed in far enough. If that is the case then you are pressing it in instead of out.
Tiger862
2018 Grand Caravan
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384372 03/24/20 08:50 AM
B
B
Maybe I’m bad at describing things.
But this video is what I’m doing. Ball joint part starts at 1:25- ends about 2:15.
https://youtu.be/CJrMvjdhCDA
Granted I’m on the ground but my IR2135 impact couldn’t press more. And the large threaded rod started to get damaged. So I stopped.
My toys
Maintaining
-16 Jetta 1.4T 20k
Re: Ball joint getting the best of me. [Re: bowlofturtle] #5384378 03/24/20 09:04 AM
E
emmett442 Offline
E
Yeah, rust can make it difficult.
I have good luck using a combination of methods.
First, load it up tight with the press.
Second, smash the knuckle where the ball joint is pressed in with a mallet.
Reload the press
Smash
Press
Smash
Sometimes to get it started, you have to throw a round of heat (on the knuckle) in there.
Air hammer is a tremendous help over a mallet, but both get the job done.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
