2018 chevy express passenger van
by Fitter30 - 04/04/20 04:01 PM
Twilight Zone
by 2015_PSD - 04/04/20 03:57 PM
Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
91 registered members (Andreeas1978, ammolab, 2015_PSD, 41Pack, 55hambone, 6 invisible), 2,449 guests, and 17 spiders.
Topics303,591
Posts5,237,899
Members71,094
Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 #5384093 03/23/20 09:10 PM
sajohnson Offline OP
Not trying to start a war -- just looking for opinions as to which oil would be best to use in a 2008 Sprinter 3500 with a Winnebago box on it (running full GVW, mountain roads, engine braking, high rpm).
In the past I always used Valvoline SynPower 5W-40, but after going thru the Mercedes 'BeVo' lists for their 228.51/229.31/229.51 approved oils I find exactly zero (o) in 5W-40 or 10W-40 weight available in the USA.
So, going on the assumption I'm stuck with 5W-30, and wanting to stay away from the ultra high-end 'boutique' oils, I'm considering both the Mobil 1 and the Rotella T6.
Both happen to be on sale right now at NAPA for about the same price, around $5.75 per quart:
https://www.napaonline.com/en/p/SHR550046251
https://www.napaonline.com/en/p/MOR124044?ref=MA==
Again, not looking to start a pillow fight, just wondering if there are any significant difference between the two.
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5384125 03/23/20 09:37 PM
sloinker Offline
The M1 5W30 Euro spec 504/507 is probably the best bang for the buck imo.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5384193 03/23/20 11:25 PM
L
loneryder Offline
L
Valvoline MST 5-40 is a 229.51 oil. Napa puts it on sale and can order it for you. 5-40 oil is what that engine was designed for.
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sloinker] #5384197 03/23/20 11:30 PM
Thanks for the tip, but I need to stick with Mercedes 228.51/229.31/229.51 approved oils. I don't see the Euro Spec oil listed on the MB 'BeVo' tables.
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: loneryder] #5384208 03/23/20 11:51 PM
Thank you!
There are three 5W-40 oils made by Valvoline on the MB 229.51 list. I searched for all 3 earlier but must have copied the listing from BeVo. They have it as "Valvoline Advanced MST 5W-40". When you use that wording, nothing that's 229.51 approved comes up. Using just "Valvoline MST 5-40" works. Very strange.
Anyway, good to know. I'd about given up on finding an MB-approved 5W-40 weight oil.
I like to buy a lot -- maybe 12-14 cases at a time, so now I need to wait for a sale.
BTW -- when I searched NAPA they only have the Valvoline SynPower MST Motor Oil 5W30 listed. Maybe they stopped carrying the 5W-40?
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5384222 03/24/20 12:39 AM
E
edyvw Offline
E
M1 5W30 ESP is approved for MB229.51 and slew of other approvals. Also, it is probably one of the best MB229.51 oils.
On Amazon you can get Motul X-Clean 5W40 that is approved of MB 229.51.
Take into consideration that thickness difference between oil such as Valvoline 5W40 MST (I used it in BMW X5 35d) and Mobil1 5W30 ESP (also used it in BMW) is some 7-9%. So, you can go easily with 5W30 and not lose any sleep.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5384246 03/24/20 03:25 AM
Snagglefoot Online Content
Online Content
Motul 8100 X Clean 5w40 MB229.51 Dexos 2 $39 per 5 liter jug on Amazon.
If you want the job done right......do it yourself.
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5384248 03/24/20 03:31 AM
Online Content
Motul 8100 X Clean + 5w30 MB 229.51
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5384249 03/24/20 03:38 AM
Online Content
Pennzoil Platinum Euro L 5w30 MB229.51. Dexos 2 $22.68 per 5 quart jug at Walmart.com.
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5384463 03/24/20 10:35 AM
L
loneryder Offline
L
Thank you!
Yes NAPA doesn't list it. When I go to NAPA to order it on sale, they have to look it up in the Valvoline catalog they have. I also think they have changed the name but if it says MST it's Medium Saps Technology. Maybe they didn't get approval on the new name. Eddyvw was in a discussion about this some time back.
I have the OM 642 engine in my 08 ML. It has never used oil with 5-40 oils but when I used the Mobil 1 ESP 5-30, it started using oil. Went back to 5-40 and it stopped. Just my experience. I would not go over 6k oci on that vehicle. That would be "severe service" hauling that weight and pushing all that air.
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: Snagglefoot] #5385506 03/25/20 03:01 PM
Thanks Snagglefoot! I wasn't aware of that. I may just go that way.
Some of the guys over on Sprinter-Source.com have gotten so fed up with trying to find a 5W-40 weight oil with MB 229.51 approval that they are using Shell Rotella T6. The ash content is low at <1.0%, but MB 229.51 calls for 0.8% or less. No one seems to know whether that slightly higher ash content will cause earlier DPF failure. One thing those of us with RVs have going for us is mostly highway driving with the engine under moderate to heavy load. Very little idling, short trips, or city traffic. The consensus seems to be that under those operating conditions at least, the Rotella T6 should be fine.
T6 has the advantage of being readily available, and it's relatively inexpensive, esp when purchased in bulk. Tractor Supply has 2.5 gallon containers for $56:
https://www.tractorsupply.com/tsc/p...w-40-heavy-duty-motor-oil-25-gal-1292172
That said, the Motul has MB 229.51 approval. It is more expensive, but not too bad. I found Motul 8100 X Clean 5w40 MB229.51 Dexos 2 on eBay for $222 for 6 each 5 liter jugs, delivered. That's $37 each or $7.40 per quart. That was using 'WikiBuy' from the Amazon listing. FWIW, the seller has 100% positive feedback with over 6,900 sales:
https://www.ebay.com/itm/MOTUL-1020...-Oil-1-3-Gallon-x-1-BOTTLE-/401131266409
General forum question: Is there a way to get email notifications of new posts in a thread?
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5385518 03/25/20 03:14 PM
K
kschachn Offline
K
Which quite frankly is dumber than bricks since Mercedes-Benz approval 229.51 states 0W-, 5W- and 10W-X grades are acceptable as part of the approval language. What that means is that anything is allowed in terms of grade except a winter rating of 20W.
What is required by the approval is an HTHS of 3.5. This makes the resulting grade irrelevant except for winter rating, and Mercedes-Benz properly accounts for that in the approval requirements.
As is always the case with Mercedes-Benz approvals you should buy the least expensive oil you can find which actually carries one or more of the approvals required by your owner's manual. You can pick a winter rating appropriate for your climate, or just pick a 0W or 5W rating and forget the rest.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: loneryder] #5385522 03/25/20 03:24 PM
Thank you!
Thanks loneryder, I'll call NAPA and see what they say. If I can get the same stuff I've been using (P/N VV966) 5W-40 that would be great. It's not on sale right now (Mobil 1 is) but I'm not in any hurry. If they can get the 5W-40 Valvoline and I can catch it on sale that would be ideal. When the Valvoline is on sale it's about the same price as Rotella T6.
Otherwise, if NAPA tells me they can't get 5W-40 Valvoline, I guess it'll be between the Motul 8100 X Clean 5w40 MB229.51 Dexos 2 and the Rotella T6 5W-40.
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5386240 03/26/20 01:24 PM
L
loneryder Offline
L
I would visit a store to make sure they really look for it. The first time I went in they couldn't find it. After looking for awhile they found it and ordered it from their warehouse which is in Pa. If I can get it at a small NAPA in Romney, WV., you should be able to get it in Md. It may come on sale next month as they usually alternate between Mobil 1 and Valvoline.
Re: Mobil 1 ESP 5W30 vs Shell Rotella T6 Multi-Vehicle 5W-30 [Re: sajohnson] #5388481 03/29/20 08:58 AM
O
OilReport99 Offline
O
Pento High Performance II Engine Oil (5w-40) - 5 Liter - $33.39. It's 229.51 approved.
https://www.ecstuning.com/b-pentosi...-5w-40-5-liter/pen-space-5w-40-space-5l/
