RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
28 registered members (Char Baby, 73guna, alcyon, AC1DD, blufeb95, 2 invisible), 1,133 guests, and 19 spiders.
Topics303,700
Posts5,240,224
Members71,116
What To Use to Seal Transmission Tube To Trans Body #5383751 03/23/20 01:44 PM
F
Fitz98 Offline OP
F
I pulled the transmission tube from my 98 Expedition with the 4r100 Tranny.
It is a 2 part tube. The upper part is long and curvy and has an o ring seal on it.
The lower part is an offset elbow that presses into the transmission body.
There is no seal or o-ring where that lower part inserts into the transmission.
That connection is a source of a transmission leak.
What should I use to seal that connection back into the transmission body?
It looks like the last time someone serviced that part they used RTV and Teflon tape, which did not work.
[Linked Image]
Re: What To Use to Seal Transmission Tube To Trans Body [Re: Fitz98] #5383753 03/23/20 01:48 PM
O
OVERKILL Offline
O
Ford Grey RTV, it'll seal that up tighter than a nun's you know what.
Re: What To Use to Seal Transmission Tube To Trans Body [Re: Fitz98] #5383774 03/23/20 02:17 PM
F
Fitz98 Offline OP
F
Same one used for rear differential? TA-29
Re: What To Use to Seal Transmission Tube To Trans Body [Re: Fitz98] #5383777 03/23/20 02:22 PM
O
OVERKILL Offline
O
TA-31 is the stuff I believe? But the TA-29 should be more than sufficient.
Re: What To Use to Seal Transmission Tube To Trans Body [Re: OVERKILL] #5383792 03/23/20 02:39 PM
L
Lubener Offline
L
LOL
The "thinking" man's friend.
Re: What To Use to Seal Transmission Tube To Trans Body [Re: Fitz98] #5383954 03/23/20 05:50 PM
CT8 Offline
You will need to have the surfaces that you are going to seal oil free.
2015 F150 2.7
2018 F350 6.2
Re: What To Use to Seal Transmission Tube To Trans Body [Re: Fitz98] #5384000 03/23/20 07:10 PM
P10crew Offline
Go to your dealer and buy a new one.
Re: What To Use to Seal Transmission Tube To Trans Body [Re: P10crew] #5384049 03/23/20 08:26 PM
K
kstanf150 Offline
K
Yep
Going cheap never works for long !
Re: What To Use to Seal Transmission Tube To Trans Body [Re: Fitz98] #5384112 03/23/20 09:22 PM
samven Offline
I dont know for sure but can you check and see if there is a groove cut inside the transmission port for an O ring.Someone may have pulled the tube out and either the Oring disintegrated or was pushed into the tranny as they tried to reinsert the tube.
Re: What To Use to Seal Transmission Tube To Trans Body [Re: Fitz98] #5384115 03/23/20 09:27 PM
P10crew Offline
My experience with those tubes is that they only fit tight once.
Re: What To Use to Seal Transmission Tube To Trans Body [Re: P10crew] #5384130 03/23/20 09:46 PM
4WD Offline
Yeah, a zero clearance fit probably means something needs to plastically deform …
Gonna be the thin tube and then it’s been necked down.
Re: What To Use to Seal Transmission Tube To Trans Body [Re: P10crew] #5384202 03/23/20 11:39 PM
F
Fitz98 Offline OP
F
I am not sure I know what you meant by this. I could interpret it to mean the original tube would only fit tight once if it was to be reused, or could mean the hole in the transmission case could get enlarged, so even a new tube would not fit tightly.
I can still see factory cross hatching at the base where it press fits in place and also some areas with factory paint still in tact, so I am assuming the bore in the case may be slightly enlarged. Perhaps partially due to the fact that the dipstick tube was not bolted in place from previous mechanic and vibration worked it loose.
I had one transmission guy tell me he JB Welds the tubes in place when they leak.
Would I be better to JB Weld if the case hole is slightly enlarged to bring it back to a tight fit, or go with the Ford Grey RTV to gasket seal it? Perhaps even hylomar blue?
I will be able to see this from the bottom with the pan removed, so I can be sure that there will be no contamination into the transmission or fluid, and will be able to clean all the surfaces well.
Re: What To Use to Seal Transmission Tube To Trans Body [Re: Fitz98] #5384843 03/24/20 06:27 PM
F
Fitz98 Offline OP
F
Ended up buying a new tube from dealer.
It has what appears to be some white Teflon coating painted on (Not the tape kind).
[Linked Image]
Does this seem like a sufficient seal? Part of me wants to scrape it off and use the Ford Gray RTV instead, but it seems like it must come this way from the dealer for a reason. I imagine just to make it a little more lubricated to press in.
