Which HM oil for minor seeps?
Idaho
After finally fixing the leaking block off plate on my 6.2L Yukon I am able to see some additional seepage from the oil pan and what appears to be the front timing cover. Not too serious, but some minor seepage. Stays dry for about a week and then some moisture can be seen. I've been running the Havoline smart box, but thinking about trying the HM version to see if it changes anything. It appears that Mobil 1 HM seems to still be on the thicker side of things - most HM formulations lately are thinner than they used to be (see Maxlife). So which HM flavor would you choose? Havoline HM, Mobil1 HM, or something else?
I've used Supertech, Valvoline and pennzoil high milage formulas and so far the best "High Milage" specific results out of that for me came from the valvoline in the form of less seepage from somewhere under my previously owned XG350. At the time I didn't really care to see where it came from.
If you are really worried about getting thicker you could up a viscosity grade.
I've been thinking about using Supertech Synthetic 5w30 HM in my Impala. It's dexos approved and $14.88 for 5 quarts. If I don't like it after a couple of OCIs, I'll get something else.
Go for it. If nothing is on sale there's no glaring reason not to and I've used that brand, viscosity and package in both my vehicles and so have a good portion of my friends.
The detailed specs for the vanilla and HM Super Tech were posted here on BITOG. All specs for the vanilla vs. HM Super Tech were identical.
Super Tech 0w-20 & 5w-20 Oils made by Warren Distribution
Go with the M1 HM. You know it's radically different than the vanilla HM and has a lot more seal swellers and cleaning ability (probably through higher Group V alkylated naphthalene (AN) content).
This is my second Simpsons reference today, but I need an illustration.
[Linked Image from 4.bp.blogspot.com]
Agree Gokhan
All repairs are going to cost more.... in this case, cost more than just the price of the next oil change.
If one finds the $10 extra too painful to the wallet, use the Supertech.
Originally Posted by ka9mnx
Thicker oils or HM oils will not fix a gasket leak.
This is true. My leak is small enough that I thought I'd give the HM oil a shot. Also, I've read here that HM oil sometimes has extra "robust" additives which may or may not be the case. I've actually fixed the problem with a scoop of oil dry as it is.
Originally Posted by Gokhan
Go with the M1 HM. You know it's radically different than the vanilla HM and has a lot more seal swellers and cleaning ability...
Oy vey!!!
What 'seal swellers' and 'cleaning ability' can be documented in a TDS???
Oy vey!!!
Are you ever going to read the posts before you reply to them? The Super Tech and Super Tech HM are identical formulations to every decimal in the the detailed data sheets. The M1 vanilla and M1 HM are entirely different formulations.
The answer to your question regarding the details of the seal swellers and cleaning ability is obviously whatever they choose to document:
https://www.mobil.com/en-US/Passenger-Vehicle-Lube/pds/NA-XX-Mobil-1-High-Mileage-Oils
Note 1 -- If your engine has excessive sludge deposits due to less-than-adequate maintenance practices, Mobil 1 High Mileage can help by reducing the sludge left behind in your engine. For severe cases of sludge, short oil change intervals (3000 - 5000 miles) are recommended for the first 2-3 oil changes as reduction of the sludge takes place. In cases of engine damage that may have resulted from poor maintenance, even Mobil 1 cannot remedy years of neglect.
Features -- Advantages and Potential Benefits: Seal Conditioner -- Helps to prevent leaks
----------------Super Tech vanilla----------------
Description
ST FS 0W20 dex1 Gen2 6/1Q
Inspection Information Test Method Typical Value
Gravity, °API ASTM D287 35.66
Specific Gravity @ 60°F (15.6°C) ASTM D4052 0.8465
Flash Point, °C ASTM D92 226
Flash Point, °F ASTM D92 439
Viscosity @ 40°C, cSt ASTM D445 44.59
Viscosity @ 100°C, cSt ASTM D445 8.475
Viscosity Index ASTM D2270 170
Pour Point, °C (°F) ASTM D5950 -45°C (-49°F)
Cold Cranking Simulator at (°C), cP ASTM D5293 5800 (-30)
High Temperature / High Shear Vis at 100°C, cP ASTM D6616 5.76
High Temperature / High Shear Vis at 150°C, cP ASTM D5481 2.7
Noack Volatility, % loss ASTM D6375 13
Color ASTM D1500 3
Zinc, wt. % ASTM D5185 0.085
Phosphorus, wt. % ASTM D5185 0.076
Calcium, wt. % ASTM D5185 0.135
Sulfur, wt. % ASTM D4951 0.3
Magnesium, wt. % ASTM D5185 0.059
Boron, wt. % ASTM D5185 0.023
Molybdenum, wt. % ASTM D5185 0.0079
Sulfated Ash, wt. % ASTM D874 0.9
Nitrogen, wt. % ASTM D4629 0.104
Pumping Viscosity at (°C), cP ASTM D4684 21,000 (-35)
Shear Stability, Final Viscosity in cSt ASTM D6278 7.5
Foam Seq. I (Tendency/Stability), mL ASTM D892 (Opt. A) 0/0
Foam Seq. II (Tendency/Stability), mL ASTM D892 (Opt. A) 5/0
Foam Seq. III (Tendency/Stability), mL ASTM D892 (Opt. A) 0/0
High Temperature Foaming, static foam ASTM D6082 (Opt A) 20/0
TBN, mgKOH/g ASTM D2896 7.9
Claims Information
API SN PLUS Approved
API SN Approved
API SM Meets Requirements
API SL Meets Requirements
API SJ, SH, SG, SF, SE, SD, SC Meets Requirements
dexos1 gen 2 Approved by Brand
Chrysler MS-6395 Meets Requirements
ILSAC GF-5 Approved
ILSAC GF-4, GF-3, GF-2, GF-1 Meets Requirements
GM 6094M Meets Requirements
GM 4718M Meets Requirements
Ford WSS-M2C947-A, WSS-M2C947-B1 Meets Requirement
----------------Super Tech HM----------------
Description
WM HM FS 0W20 DX2 6/1Q
Color ASTM D1500 3
Claims Information
API SN Approved
ILSAC GF-5 Approved
I think I will try Mobil1 HM because I can pick up the exact amount I need (6 quarts) at Sams Club. I may wait until April starts to see if the rebates come out.
Supertech FS/Supertech FS HM are the exact same thing? How do they not get in trouble for false advertising? That makes me not want to use the regular Supertech FS if that's the case. If they will put the same product in two different jugs and say one is HM, there's no telling what else isn't true.
For a noticeable while here in SE Michigan, they were labeling Supertech Dino as Dexos 1 Gen 2. Then one day, all those jugs were gone and the new labels had no Dexos 1 Gen 2 on the dino oil.
Shady business practices there.
They may have higher seal conditioner content in both...
