KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
40 registered members (bachman, blufeb95, Alaskanmont, 928, bernau, 6 invisible), 1,351 guests, and 19 spiders.
Topics303,554
Posts5,237,343
Members71,086
Bad PCV valve? '99 Taurus #5383576 03/23/20 09:59 AM
A
atikovi Offline OP
A
It rattles when I shake it like it's supposed to, but if I blow or suck on the hose end of it, air flows freely. Isn't it supposed to block flow in one direction?
Re: Bad PCV valve? '99 Taurus [Re: atikovi] #5383582 03/23/20 10:07 AM
M
mk378 Offline
M
No. It's a restriction not a check valve. The restriction increases when there is high vacuum, but it never completely closes.
Re: Bad PCV valve? '99 Taurus [Re: atikovi] #5383585 03/23/20 10:09 AM
9
97prizm Offline
9
Mine acted like this and caused an excessive oil leak. I replaced it and now its much better.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Bad PCV valve? '99 Taurus [Re: atikovi] #5383594 03/23/20 10:16 AM
W
WyrTwister Offline
W
The PCV valves I have replaced have been fairly cheap . In that case , if in doubt , replace it .
Wyr
God bless
Re: Bad PCV valve? '99 Taurus [Re: atikovi] #5383601 03/23/20 10:26 AM
A
atikovi Offline OP
A
16 bucks for Motorcraft although aftermarket is $4 plus the hose is pretty cracked so another $13. Could this be why it goes to over 2000 rpm on a cold start for a few seconds?
Re: Bad PCV valve? '99 Taurus [Re: atikovi] #5383629 03/23/20 11:01 AM
R
ragtoplvr Offline
R
do not forget the hose and passage into the intake. They can have sime buildup and plug, also seen the liner separate and collapse. If you replace do not get cheap hose.
Rod
Re: Bad PCV valve? '99 Taurus [Re: atikovi] #5383680 03/23/20 12:10 PM
J
Jackson_Slugger Offline
J
I picked up a Motorcraft PCV for a 3.0L 24v ordering at WM for about $10...
Re: Bad PCV valve? '99 Taurus [Re: atikovi] #5383839 03/23/20 03:31 PM
O
oldhp Offline
O
Don't use fuel line hose, too thin. When ever I've replaced hoses I used automatic transmission hose, thicker wall. If your replacing the PCV replace the hose too.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
